24# Injectors
    24# Injectors
    Since I have the 24#ers laying around I fugured i'd pop them in just to see what would happen.
    I think that the thing does have a bit more zap up top with the 24s vs the 21.5s, I sorta figured that with the M50 manifold that the motor could use a bit more north of 4500 where the manifold is supposed to flow more.
    She runs fine at idle and putting around...
    hmm... do u think it was necessary to have the 24's with the M50? i mean they don't require it.. but hmmm..
      you are wasting your time if you think 24# injectors are going to make any difference whatsoever over 21.5# injectors.
        totally agree.
          HOWEVER
          if done in conjunction with appropriate cams, intake plenum, headers, TB and exhaust crank HP of 300+ can be had. Ask BMWCCACR IP racers.
          Dan Law
          [email protected]
            The butt dyno and the rate of clockwise tach spin up tells me that the little blue guys did do something...Nothing earth shattering, but I really do notice a little differance.
            Swapping injectors is like a 10 minute operation, and like I said I had the 24s lying around, so being bored I popped them in.
            I would like to do the cams but I need to do some more research on thier ability to pass California Smog. Pulling off a manifold would ****, but having to swap cams back for smog would be totally impractical...
              HOWEVER
              Dan Law
              [email protected]
              Thats what they are sold for :chair: ...not what this thread is about.
