Is the M50 Manifold worth it? (those who actually have one in a '96+ E36 M3 please)
    The fit IMO is fine, I can’t really tell anything isn’t stock at first glance, unless you know these engines by the years. And as for the power, I like it (I do more highway driving so I guess that’s why…) but the torque I can’t really feel too much of a loss down low. My friend has a 97’ M3 stock and I drive it once in a while, mine feels almost like his down low but up in the higher rpm ranges I just pull so much harder (not just butt dyno but highway proven lol). And if your going to go fast its not going to be in traffic I would guess, so the high rpms isn’t so bad for power delivery. Just look at my dyno chart (link below) but as you can see the horsepower never falls all the way to the 7000 rpm redline.
    But in the end I guess it’s really up to your driving style.
    Jon, what are all your mods for the dyno?
      After reading this thread i am considering getting an M50 manifold. Around how much are they and where do you get them? Anyone know typical hp/tq gains on a mostly stock M3? Also, how is install on these?
        Mine gets shipped out thursday, Ill let yall know afterwards.
          I did mine about 5 months ago. The car pulls great all the way to redline, not like before when it would level off. I may have noticed a little loss down low but not even comparable to the gain up top. Great mod for our 3.2's
            someone educate me real quick on the M50 manifold. I got a 95 M3 so I'm guessing this will not work for my car but out of curiosity, is the M50 manifold a stock part from some european M3s or something (although it can't be cuz they got ITBs right?)
            wait...after some searching, I believe the M50 is off of the 95 OBD1 M3 ??? if so then I already have the manifold and won't need this mod???
              search :chair:
                I have a question...
                I've seen a couple places that you need the conforti shark reprog once this is done. Who agrees? Is this BS? I have Dinan Stage 3 SW. Would I still need to reprogram?
                  You do not need software for this manifold conversion, however it wouldnt hurt to ditch that Dinan software...
                    Whats the difference between this one and understeers eurosport model. I know the link I posted has a fuel rail cover that fits but it looks like understeers has more things like the metal thing that attaches to the manifold.
                    http://m50manifold.com//index.php?option=com_content&task=view&id=28&Itemi d=43
                      Lucy...? 'Splain....
                        The M50 manifold is what you have on your 1995 OBD I M3.
                        The manifold was changed in 1996+ due to the implementation of OBD II and stricter emissions standards. As a result of these standards, BMW made the 96+ m3s with a more restrictive setup and a larger 3.2 L engine.
                          Eurosports kit is a nicely machined aluminum adapter that uses as much OEM hardware as possible, and simply lowers it and bolts it all to the OBDI manifold.
                          That kit linked is alot cheaper, and as well it should be.. its basicly some couplings and hose.
                          Both are functionally the same, chose which one is best for you based on your budget, and your OCD about such things.
                            Speaking of OCD, you still need to fix your cluster... It'll make up for the body kit :ha:
                              I still wanna know what the predjudice against the Dinan SW is...
                                maybe the high brand name price with such a conservative tune... so many different 'stages'...?
