Step 1: Drive front of car onto 2x4 wood blocks to gain jack clearance.
Step 2: Place jack pad (saddle) beneath front sub-frame cross-member.
Step 3: Raise car and place jack stands underneath pucks.
Step 4: Place saddle under rear sub-frame cross-member, just forward of the differential.
Step 5: Raise car and place jack stands underneath pucks.
I would add that I split the weight difference with a 2 x 6 between the rear-frame cross member and diff housing. And get my jack stands under the rear jack pads quickly. Either spot is bad for jacking, but jacking them together is the best approach.
Jacking one side and then the other is not good on your aging suspension components or chassis.
