has anyone recently installed a set of these? The directions said to put the enforcer cup at the top of the transmission mount. i accidentally put it at the bottom.
The reason why was because the black tranny mount itself has a little pea sized divot in it that goes directly on top of the mounting plate that holds up the transmission. It seems to be divited to stop the tranny mount from spinning while you are tightening the bolts.
Contrary to the picture of the enforcer cup on UUC's site, my enforcer cups had the same pea sized divot in it that the black tranny mount has which led me to believe the enforcer cup's divot was to line up with the tranny mount's divot and was to be installed at the bottom of the tranny mount. The enforcer cup on UUC's site was just a plain cup with no holes/divits in it.
My question is if you were to install the enforcer cup at the top of the tranny mount, then why else would it have the same divot as the tranny mount uses to stop it from spinning while you tighten the mounting bolts..
here is the picture of the misinstalled tranny mounts. I have not/cant drive the car for 3-5 more weeks as i am diy-ing the crap out of it, so im ok with redoing it if suggested to.
http://i724.photobucket.com/albums/ww247/mesa3077boogie/_J200132.jpg
