You wouldn't believe it if you knew what happened.
After the paint job, which I loved, the headlights were broken. The fog lamps and high beams no longer worked. Left directional flashed extra fast. When I looked under there, the gray wire on one side broke off when I touched it (there are four pins). I also had the suspension clunk. The paint shop said they didn't do suspension work so I took it to Pep Boys across the street who had done a decent job. They couldn't figure it out and messed up my door handle fixing the latch (which broke after the paint job). So I went to another shop that recommended the same place that painted it. So I went back there and they took me to the sister shop. They couldn't fix the suspension (though it's improved now and I think a spring was sideways). New tires on the way.
BUT when I looked at the headlights which they said they fixed - I had said I wanted a harness to thread onto the (glass) headlights - but they Jury-rigged four wires - bypassing the four pins. Now there are lots of the same two-prong connectors that are grey and black - but the plastic covers on the headlight assembly for the wires are off because wires are now coming through. I just got my Bosch set in the mail and don't know how to install them because of what they did.
It gets worse - 1) the OBC is flashing "Low Beam Failure" constantly, even though they work. 2) When I turn my corner lights on, the headlights come on - there is no difference with first and second stage lights now. 3) The inner lights that are high beams but also low output normally no longer work at all. 4) AND... They forgot ALL four screws holding the headlights on. $208.00. Of course I found it Friday at 6:01PM when everyone was closed.
