On the hunt for 3 channel ABS racing calibration (trade for Gruppe N Vanos file?)
    I am trying to track down a 34-50-2-483-756​ ABS EPROM, which was (I think) the Gruppe N ABS calibration for the 3 channel ABS. Or, as a backup, I would settle for the BIN file, which I can try to write to a spare ABS module. I am sure I had this file, saved securely on a backup drive, but the drive is now so safe that I cannot find it.
    In the process of searching for the file, I did find racing Vanos calibration files for the 3.0 Vanos controller (S50B30 with M3.1 DME), so if you fancy a trade, that's an option.
    Try contacting Wayne at Chipwizards in the UK:
      There's also this:
      Motorsport upgrade E36 3-channel ABS The well-known "Motorsport Eporm" data as of 1993 With this upgrade you get the most out of the old 3-channel ABS. The data status is optimized in terms of control speed, control variable and characteristic curve for tires with more grip on the racetrack. It can be exchanged Plug...
      '01 M3, Imola/black
        This will NOT work with the ABS units fitted to USA 1995 M3s, I've contacted them and asked.
          Interesting, are 96+ US cars compatible or also no?
          Any reason not to do a MK60 swap, aside from complexity and cost?
          '01 M3, Imola/black
            3,2L
            05 Control unit ABS 3,2L GR.N MK IV 1 34522501347 $3641.95
            3,0L
            05 Control unit ABS 3,0L GR.N MK IV 1 34522223706 $7826.91
            Just for documentation purposes ​
            Build Thread:
              No. 96+ is 4-channel, so also not supported.
              MK60 swaps are getting easier with aftermarket solutions.
                Sandman, have you had any luck in tracking down the EPROM dump? I've also been looking into this as of recently. I believe the EPROMs can be soldered into the US Spec 1995 E36 M3 34521138219 ABS control unit. There isn't very much info available online about these "motorsport" EPROMs, and I'm very curious about them. It is a different EPROM to what comes in the US Spec 1995 M3 module, as we have M83C154P EPROMs, and the "motorsport" EPROM is an AN87C51FC. So even with the dump, the chips will also have to be replaced. These EPROMs should be able to be read and written with a TL866-3G or similar, although I have yet to personally test that. This seems like a possible nice upgrade for 3-channel cars without committing to converting to 4-channel and an MK60.
                Thanks,
                Joel
                  There are a couple sources for the 3-channel Race EPROMs still, including mk-motorsportteile.de. Though I do not know a source for the BIN file if you understandably don't want to pay the exorbitant cost of having a module modified elsewhere.
                  Since several in this thread seem knowledgeable on the subject, can a "race modified" p/n 34521138219 module be used with ANY E36 3-channel pump? There are a lot of variations, although the Group N catalog listed the same part number as the US 1995 M3 pump. These were the "open" systems with low pressure lines running from the pump to the brake fluid reservoir. Later models had "closed" pumps without the lines going to the brake reservoir. Further, I saw an old post saying that there is an early model "Euro M3" pump that is necessary, but I haven't found any information to corroborate that.
                  I have two pumps; the one on the car is an "open" pump, and the other is "closed." Trying to decide which I should use, or if I need a different/special unit entirely, before moving forward.
