On the hunt for 3 channel ABS racing calibration (trade for Gruppe N Vanos file?)
    I am trying to track down a 34-50-2-483-756​ ABS EPROM, which was (I think) the Gruppe N ABS calibration for the 3 channel ABS. Or, as a backup, I would settle for the BIN file, which I can try to write to a spare ABS module. I am sure I had this file, saved securely on a backup drive, but the drive is now so safe that I cannot find it.
    In the process of searching for the file, I did find racing Vanos calibration files for the 3.0 Vanos controller (S50B30 with M3.1 DME), so if you fancy a trade, that's an option.
    Try contacting Wayne at Chipwizards in the UK:
      There's also this:
      Motorsport upgrade E36 3-channel ABS The well-known "Motorsport Eporm" data as of 1993 With this upgrade you get the most out of the old 3-channel ABS. The data status is optimized in terms of control speed, control variable and characteristic curve for tires with more grip on the racetrack. It can be exchanged Plug...
        This will NOT work with the ABS units fitted to USA 1995 M3s, I've contacted them and asked.
          Interesting, are 96+ US cars compatible or also no?
          Any reason not to do a MK60 swap, aside from complexity and cost?
            3,2L
            05 Control unit ABS 3,2L GR.N MK IV 1 34522501347 $3641.95
            3,0L
            05 Control unit ABS 3,0L GR.N MK IV 1 34522223706 $7826.91
            Just for documentation purposes ​
            Build Thread:
              No. 96+ is 4-channel, so also not supported.
              MK60 swaps are getting easier with aftermarket solutions.
