Hi There - Just wanted to document this in the forum, the sender unit has developed a crack and is leaking out some fuel that ultimately sits at the top of the unit. I've already ordered a replacement unit and in the meantime i put some JB Weld to prevent fuel coming out, unsure how long it will last but its a temp solution until the new unit arrives.
I will also try to replace the cap of the old unit with that of the regular 3 series (i think it should work) in an attempt to find a more cost effective solution to the oem pump, there is nothing wrong with the current unit aside from the crack it developed by using cheap plastic, ive done this before on my e46 when i replaced the oem pump with the radium engineering stock pump kit.
Best,
Irhase46m3
Best,
Irhase46m3
