Follow-up from this thread: https://nam3forum.com/forums/forum/e...ension-service
After some delays, work has finally started – though it has had to be split up into two stages. Here's what's getting done right now:
- Clutch kit (OE LuK)
- Flywheel(OE LuK)
- Driveshaft (BMW)
- Differential (Diffsonline – 100% stock spec)
- Autosolutions shift kit (+40mm extended lever, 15% throw reduction)
- All bushings in rear subframe (Bimmerworld solid subframe mounts; all else OE)
- All rear suspension arms & bushings/balljoints (OE BMW/TRW/Lemförder etc.)
- Rear ARB end links (SPL)
- Rear ARB bushings (OE)
- Less-old stock muffler
- Re-grease & re-boot rear CVs
- Rear main seal
- Trans output shaft seal
- Shift shaft seal
- Rear subframe powdercoating
- POR-15 on rusted areas
- Rear O2 sensors
- RL wheel bearing
- E-brake rebuild (shoes, cables, hardware)
- Trans tunnel & muffler heat shields
- Some repair/replacement of old fasteners, studs, etc.
- 513M wheels, stock 245/265 tire sizes
Also planned, but delayed because Bosch apparently can't decide if/when it'll build steering racks:
- Steering rack (new Bosch)
- Steering rack boot
- Front wishbones (OE TRW)
- Front ARB bushings
- PSF reservoir
- Engine mounts (Corteco)
After I get the car back on the road, I'll do my best to offer useful commentary about how it drives. But at that point it'll have been 2 months since I've driven the car at all, so anything I say will have to be taken with a grain of salt.
Also I'm terrible about taking pics and the car isn't with me, but I'll post what I can.
- Flywheel(OE LuK)
- Driveshaft (BMW)
- Rear main seal
- Shift shaft seal
- Rear O2 sensors
- RL wheel bearing
- PSF reservoir
