Help me pick my next track pad
    HPDE novice. Done a few events at NJMP Thunderbolt and Lightning; will likely stay on those tracks for now. My E90 6MT is mainly a street car. 245f/265r tires, PS4S or an endurance 200TW tire (AD09, R-S4, NT01, etc.). Öhlins R&T. Stock powertrain. No aero. Stock weight.
    F8x front spindle & brake swap coming soon. Looking forward to that!
    ​So far, I’ve tried Hawk DTC-60 and Ferodo DS2500, and disliked both. DTC-60 was inconsistent for me (I suspect because I couldn’t always keep enough heat in them) and easily overwhelmed the tires and ABS. DS2500 was a far better fit but didn’t quite have enough performance. Both had a lot less initial bite than I want, requiring me to get deeper into the pedal, and that sapped my confidence.
    Might Pagid RSL29 be worth a shot? If so, that’d be my first choice as ECS sells it with lifetime replacement.
    If not, how about PFC 08 or 11? Or would those be overkill?
    I’m aware there are many other options and the best way is to experiment. What I’m hoping for here is to find the options that have the best odds of success so I can prioritize those.
    Grateful for any feedback!
    2008 E90 M3 6MT
    2011 E90 328i 6MT
    RWD, slicktop, no iDrive
    I debated pfc 08 vs ds2500 for me e46. I went with the ds2500, so I would recommend the pfc to you. My $.02
      Right up front - I'm a 16-year believer in PFC. I'm on PFC-11s, but those may be overkill for just NJMP, as it isn't all that demanding on pads. I can recommend PFC-08, but I'll suggest that you first ask yourself what your priorities for a pad are. All brands, including PFC, make a range of pads with different characteristics to meet the needs of people with differing priorities. Initial bite, heat tolerance, wear rate, ability to modulate, braking feel and noise etc all things you will come to have specific ideas about.
      Remember that braking force needs to be compatible with tire choice. A classic error is to substantially increase hot braking torque without pairing with tires with similarly increased hot performance. Tires stop cars and grip is not infinite.
        Agreed.
        I think what I want most are
        1. Strong feedback;
        2. Strong initial bite; and
        3. Behavior that's consistent over the temp range I'll see
        ...roughly in that order (though close).
        Willing to sacrifice a bit on pad/rotor lifespan, and a lot on anything not related to track use (e.g. noise, dust).
        In PFC's catalog, 08 and 11 are the only options for the F8x front calipers I'll have. I like 11 for the initial bite; I like 08 for the greater consistency in response vs. temp. So I guess the question is, how likely is it that 11 would be a handful to use with my tires? I don't mind overkill; I just don't want the pad to be hard to use. If the chance is high, then I'd lean toward 08; otherwise, 11 looks more like what I want.
        Still eyeing Pagid RSL29 and RSL1 because of ECS's LRG. But RSL29 seems to get some flak for pedal feel, which would be a big downer for me; RSL1 looks much better to me on paper, but it seems to be an unknown in this community so finding feedback on it is hard.
        2008 E90 M3 6MT
        2011 E90 328i 6MT
          Agreed.
          1. Strong feedback;
          I ended up on PFC-11s because I was on PFC-01 and they discontinued the pad shape (supposedly because of environmental concerns, but I can tell you that -01s were hell on hot wheels in the wet. It formed a ceramic-like coating that even oven cleaner couldn't remove). I moved to -11 because that was the PFC recommendation. -11 has strong initial bite (which I was hooked on from -01) but you could easily overpower good 200 TW tires with very late braking. -11 is easy to intuitively modulate and trail brake, but needs a full lap to come up to operating temperature, or you will have a drama moment. This is not an issue with PFC-11. -08 will have more pad life. I don't focus much on rotor wear - mine is normal and its a wear item (to me). I use PFC DD.
            I'm also a long-time PF01s user. I've been using Stoptech SR34s since I have stoptech calipers on both M3s which are PF01 clones but they are hard to find if not discontinued. I think later on the PF01s got a little nicer to wheels but yeah...it is like sandpaper glued to the wheel in every little corner.
            I'm on Hawk DTC70s for the lifetime warranty which are close to a PF01 in terms of bite, feel, and trail braking modulation but they don't last quite as long. Which is not a concern on my 2575lb E46. But the DTC70 is no PF01. I've been considering just spending the coin on PF11s.
            I'd be a little more worried on an E9X M3 which eats pads on stock brakes. E90 M3 on stock brakes did double duty at Road America years ago. My friend flew into WI, drove my E90. Then my E46 blew up and we were both driving the E90. That car did 20 sessions, we literally smoked 3 sets of pads - PF01s, DTC70s, and some cool carbon pads that we overnighted. I also torched a set of PF01s in 7 sessions. All of this on NT01s, not real sticky tires. A Pagid yellow, which I did not like at all, didn't last much longer.
            So might be smart to stay on a pad you can get with a lifetime warranty and sacrifice something. Maybe use the DTC70s and keep an extra set on hand.
            I think a BBK makes sense financially if you plan to track an E9X M3 for awhile...as much as anything track related makes financial sense. lol
              Good points. Thanks for sharing them.
              FWIW, I got multiple track days out of a set of DS2500, one of the most notoriously short-lived compounds for track use, so I'm probably a lot slower than you are. I'm assuming any legit track pad will be at least okay. But we'll see. Your warnings are appreciated and well taken.
              I'm super leery of Hawks after my previous experiences, but you're not the first longtime PFC user who has told me they switched to DTCs and liked them. The LRG is definitely a massive benefit.
              Speaking of which: ECS seems to have started carrying PFCs, but only a few SKUs. If they eventually add more, that'd be a slam-dunk (lifetime replacement). I emailed them asking if they're planning to add more. I'll post back if I hear anything.
              2008 E90 M3 6MT
              2011 E90 328i 6MT
                E46 invading an E9x thread!
                After my first track day at Atlanta Motorsports Park just about killed a set of street pads I went with Ferodo DS2500's for Road Atlanta. Speeds are a fair bit higher, but at my novice skill level RA was much easier on brakes than AMP.
                I felt plenty of confidence in the DS2500's. I was never worried about slowing it down. The problem was modulating them. My instructor keep asking me to go easier on the brakes in some corners - "just breath on them a bit." I could not get the hang of that, and some of it might have been my novice skill level and my primary goal of not going off.
                My instructor has both E36 and E46 track cars, so he is familiar with the platform and I thought it would help me to ride shotgun while he drove a couple of laps. It was a humbling experience. After a couple of corners he said that the brakes felt "overboosted" and that he too was struggling to modulate them.
                The DS2500's have only one track day on them, so I am not ditching them yet, but I am interested in a pad that is easier to modulate.
                E46 M3 with 996 brake conversion.
                D-O
                Old, not obsolete.
                  PFC 11
                  Build Thread:
                    I've tried DS1.11 and DTC70s with F8x brakes.
                    I liked the 1.11 more, but FCP warranty has kept me on the 70s and i've learned to adjust my driving around it.
                    If you like strong initial bite, I suggest you try the DS3.12 pads.
                      If you want more initial bite and consistency, the Pagid RSL29 could be a good starting point, especially with the lifetime replacement perk. PFC 08 is another solid choice for track use, but it might be a bit aggressive for mostly street driving.
                        So I am probably not the best source- I actually read this thread because I do not have a ton of experience with different brake pad compounds and am also an HPDE novice, but one thing you said stuck out to me- you want more initial bite and a pad that works at a slightly lower temp than the DTC 60s you're running. Allow me to introduce the current pads I am running and HATE lol, the DTC-30! I was advised to go with 30s by my first instructor after causing my HPS 5.0 pads to fade after a few laps at VIR. He said the 60s would be too aggressive for street tires and did not recommend going to a stickier tire until I was far more advanced as a driver. They definitely do not fade- a full weekend of full send around VIR, at no point did I ever doubt them in the slightest. They also get up to operating temperature effortlessly- in my everyday commute to work, there's a hill, not huge, maybe half a mile long at a reasonable grade, 55 Mph, with a stop light at the bottom. If I get caught by the stoplight, that stop is enough to get the pads in their temperature range, even now in the cold. I always discover this because when I get to the next light to turn left and touch the pedal like normal, I feel like I hit a wall lol.
                        My issue with them, though, is exactly what you want- they bite HARD as soon as you touch the pedal. Once you're on the brake, they're great. Easy to modulate, easy to trail brake, and 10/10 consistent at my pace (not blistering, but fast enough I am not getting passed constantly, and at my last HPDE, I overheated my powersteering system, despite everything being fresh). Based on what you're saying, you'll love them.
                        My problem is that I couldn't achieve the finesse to quickly shift from the throttle to the pedal without feeling like I'd thrown out the anchor, then modulating it. My instructor kept asking me if I was lifting my foot off the floor and stomping the pedal. He couldn't understand why I kept stabbing the pedal until he drove it and was surprised by them too, but to his credit, he was able to adjust his driving to the pads far more easily than I could... so maybe it is a skill issue on my part? But it doesn't seem like that- on the HPS 5.0 pads, I did not have this issue at all; they were predictable and easy to modulate everywhere, until they started to fade. Not sure... I have been trying to find reviews with similar experiences, but it doesn't seem like a compound that people run very often.
                        Also important and of note, in both cases above, I am running our 18" BBK kit that uses the Brembos from the GT350 on the front and a different Brembo caliper on the rear- I dont mean to plug here, but I saw someone else saying they're interested in an F8x conversion, so I'd like to note: we sell the full BBK, 6 pot front and 4 pot rear (all brand new from brembo), plus F8x fitment girodisc rotors and spiegler SS brake lines, brake pads of your choice, AND brand new F8x steering knuckles for $5500. We sized and specced everything to work well with the chassis and OEM master cylinder, so the kit is completely plug-and-play. The 19"+ kit is $5000, doesn't use the F8x knuckles, and includes 400 mm front and 370mm rear rotors, also from girodisc.
                        E92 M3, 6MT
                        Head​ of Engineering and Design
                        ParteeRacing.com​​
