What should I do at 110k miles?
    Coming up on 110k miles and have a few items of scheduled and preventative maintenance planned. Interested in people's opinions on anything else I should do while I'm in there.
    Already planned:
    - Engine oil & filter
    - MT fluid
    - Diff fluid
    - Cabin air filters
    - Spark plugs
    - Oil separators
    - PCV & hose (might chicken out based on what I've read)
    Done recently enough:
    - Engine air filter
    - Rod bearings & engine mounts
    - TAs
    - Thermostat, water pump, etc.
    - Belts & pulleys
    - VCGs
    - Upstream O2 sensors
    Currently have no codes, and no apparent functional issues other than some wear-and-tear that isn't urgent to address (driveshaft "tink", gear rattle, aging dampers, etc.).
    Any thoughts?
    2008 E90 M3 6MT
    2011 E90 328i 6MT
    RWD, slicktop, no iDrive
    Power steering fluid
    coolant
    idlers
    ... I replace every bushings/bearing/ball joint/drive train mount on my cars at 100,000 mile intervals to keep them driving like new...
    Once you start tracking it, you may find it's radiator time (as they get clogged up over time and become less efficient)
    2008 Black/Black M5 Sedan
    For sale: 6MT 2008 M5: https://nam3forum.com/forums/forum/c...fully-modified
      Idlers and coolant are recent enough. PSF is a good one though. Reservoir is cheap. Thanks!
      2008 E90 M3 6MT
      2011 E90 328i 6MT
        probably time for suspension don't you think?
          Yep. In the works.
          2008 E90 M3 6MT
          2011 E90 328i 6MT
            Front control arms if they haven't been done by now. They dont last much past 100
