I do have several spare MSS60 ECUs - so just to be clear (sorry for appearing dumb here!!) you want me to patch one of my spare MSS60s units, then install in vehicle and see if she starts and what codes might be logged?
EWS delete testing
Are you trying to do this on the factory dme? I thought you had a spare mss60?Originally posted by pshoey View PostNot yet - i have to remove the tune first - and of course the tune software had expired so I now that i have a new version - i can put the car back to stock, probably tonight and then try the patch.
were you able to test it yet?Originally posted by pshoey View PostYes, hex edit is no problem
I just want to make sure I a) don't fuck up my M3 and b) test the right steps so that I'm contributing useful test data.
Mainly want I need to know is what do I need to take from my existing DME (that does have a tune) for the new DME? Does EWS delete mean I don't need to do anything other than plug in the DME and it should just start?
Thanks for checking though !!
P.
gotcha.Originally posted by pshoey View PostYes, hex edit is no problem
P.
Just edit the bin at the address listed (verify your on 241e) flash the dme and check if it starts. If it does not, pull a ram read for me. If it does start, check to see what faults it has if any.
P.Last edited by pshoey; 08-28-2021, 01:24 PM.
Do you have/ know how to use a hex editor?Originally posted by pshoey View PostI have an M3 and some spare MSS60s - what would be the steps to test this?
Also, can we have one post with all the info - for MSS60 and MSS65 ? would save people paging through many posts.
I can edit the original post once it’s verified
Anyone able to test this?Originally posted by hobbit382 View PostI’ve been working on ews delete for everyone, but don’t always have a car available to test on. If anyone has a spare dme and would like to do some testing change byte 0x65387 from 03 to 01 and report back.
terraOriginally posted by terra View PostCongrats hobbit382 and thanks for sharing! Equivalent code in 520E version of MSS65 appears to be at 62DA6
Looks like I was digging around the equivalent subroutine myself in the MSS60 preproduction firmware (which appears to be EWS3 based despite being an MSS60 program) -- the actual skipped branch appears to be for the Ews_st check. Which makes sense.
Equivalent section of code in 241E seems to be at 5D2F0, but I have no idea if it actually works there.
62DA8 for 520E software MSS65 😉
unfortunately it’s not as easy on mss60. I’ve tried the same mod, it starts and runs, but misfires and throws a bunch of faults. Hopefully the mod I posted originally in this thread has some success.Originally posted by terra View PostCongrats hobbit382 and thanks for sharing! Equivalent code in 520E version of MSS65 appears to be at 62DA6
I didn’t force any RAM, I changed the branch if not equal to always branch. I wanted to change the ram to make sure it spread to other subs that might be used, but it didn’t work the way I expected. Mss65 is actually quite a bit easier than mss60 it seems. Hopefully we get some testers for mss60. I’ll be out of town for the next 2 weeks so won’t be able to test myself.
