I can't find the map you say. But I think something similar is: KL_N_BEGR_TI_OFFSET and I tried to set it to 0 and 50rpm. but to no avail.
That is the correct map indeed. You will notice less torque drop before revlimit. I logged this on a dyno. I am not sure for real hard limits by injection.
I might be able to read a 6MT motorsport ECU soon. Hopefully this shows some changes.
Not for any about "hard rev limiter" nonsense . For the moment I am in hard discussing for a rare development stage ecu.
By the way Last week new "best S65 decat power, for us" 457hp 460nm. Ignition nearly to stock (some degrees changed), most benefit from vanos maps retune and lambda (like other bmws also).
