Revlimit Motorsport MSS60 M3 E92
    Hello partners. Has anyone managed to do a quick cut by injection in these ecu?
    I tried to put these 2 maps ( K_DKBA_NMAX_HYS and K_MD_KKOS_N_MAX_HYS) at 0rpm but with no good result.
    thanks!!!
    Put the hexadecimal addresses I'll watch
      K_DKBA_NMAX_HYS = 93C4
      K_MD_KKOS_N_MAX_HYS = 17C1C
        More torque intervention.
        Try KL_N_BEGR_TI_OFF_RS set to 0?
          I can't find the map you say. But I think something similar is: KL_N_BEGR_TI_OFFSET and I tried to set it to 0 and 50rpm. but to no avail.
            That is the correct map indeed. You will notice less torque drop before revlimit. I logged this on a dyno. I am not sure for real hard limits by injection.
            I might be able to read a 6MT motorsport ECU soon. Hopefully this shows some changes.
              Please share that dump if you're able to get it
                not had time to watch, a lot of work at the moment
                sorry
                  If anyone has any news about the revlimit ... it would be good to expose it.
                    Not for any about "hard rev limiter" nonsense . For the moment I am in hard discussing for a rare development stage ecu.
                    By the way Last week new "best S65 decat power, for us" 457hp 460nm. Ignition nearly to stock (some degrees changed), most benefit from vanos maps retune and lambda (like other bmws also).
