this should help.
mostly in german but very easy to identify virtually everything
MSS60 XDF Mappings
hello i have files for M3 e92 where is make pop and bang if you can handle something with that i can give it you
There are so many variants like official MSS60 Software out there. Just the the 240e/241e share the data.
If you know how a a2l is generated you know there is no stable offset. It always depends in which address the new application data is packed. So you have a range of application data and integrate a new label it will be anywhere in this range. You have some data in front of this label with no needed offset and the data behind need the offset of the new integrated label.
I think terra's idea will be the best. Standardize 240e/241e for this thread.
I think in general it makes sense to just have everyone standardize one a single software variant. 240E/241E is probably a good one to do.
Cool idea. Please add to software version to these informations. 240e/241e aka V762 is the same but it differs to older ones.
MSS60 XDF Mappings
Hey everyone,
I'm trying to create an XDF to share with the forum with the binaries that we are reading from the MSS6X Flasher.
Just sharing some of my identifying findings using the MSS6X Flasher so far. Hopefully we can identify some more mappings! I am looking for servotronic comfort/sport addresses. pedal throttle map comfort/sport, ignition min(KF TZ VL MIN), WOT Fueling. I won't bother with cold start, o2 dtc stuff since ECUWORX tool can handle that.
Please share if you have any!
This is from 241E read.
RPM Limiter:
0x6062
1x8
16 bit
Columns: 0x6052
values:
8000 8300 8300 8300 8300 8300 8300 8300
TEMP RPM
0x6088
6x1
columns: 0x6088
row conversion: (X*0.1)-273.2 to degrees
-25.0 0.0 25.0 50.0 60.0 80.0
5000.0 6000.0 6500.0 7000.0 7500.0 8300.
Vanos Admission:
0xA862
16x12 table
16 bit
Row: 0xA82A
Column: 0xA84A
Conversion: X/10
stock values:
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 112.0 103.5 97.7
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 105.0 100.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 103.9 98.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 101.1 95.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 118.0 97.0 87.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.7 114.0 87.0
131.0 130.9 131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.6 116.0 83.0
131.0 131.0 131.0 130.0 127.0 126.0 124.0 124.0 128.1 124.0 115.7 83.0
131.0 131.0 131.2 130.0 127.0 127.0 127.1 130.0 128.5 122.5 115.7 83.0
131.0 131.0 131.0 131.0 130.0 130.0 130.0 130.0 126.6 122.8 114.9 92.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 130.0 124.4 118.1 112.4 93.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 129.0 118.6 114.2 109.3 99.8
131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.6 112.8 111.6 107.9 104.0
131.0 131.0 131.0 131.0 131.0 131.0 125.8 108.7 99.4 101.3 103.8 108.2
131.0 131.0 131.0 131.0 131.0 131.0 122.0 102.0 94.1 96.0 101.5 112.0
131.0 131.0 131.0 131.0 131.0 131.0 121.9 100.1 92.2 95.8 103.5 120.0
Vanos Admission Heating (KATH):
0xABD6
16x12
16 bit
Row: 0xAB9E
Column: 0xABBE
Conversion: X/10
stock values:
131.0 131.0 131.0 131.0 131.0 131.0 131.0 126.8 123.0 109.0 98.5 97.7
131.0 131.0 131.0 131.0 131.0 130.9 129.3 124.0 119.0 110.7 100.0 100.0
131.0 131.0 129.0 125.6 123.0 120.3 117.0 119.0 119.0 116.7 98.9 98.0
131.0 131.0 127.3 120.5 117.1 115.8 114.4 117.2 124.8 117.0 95.5 95.0
131.0 131.0 127.3 120.4 117.0 116.0 115.0 117.3 125.7 117.0 91.0 77.0
131.0 131.2 127.0 120.0 118.0 116.0 115.0 117.0 125.0 123.7 106.0 77.0
131.0 130.9 129.1 124.0 118.0 116.5 116.6 119.1 127.0 123.6 111.0 77.0
131.0 131.3 129.7 125.0 118.0 117.0 117.6 120.6 128.1 124.0 110.7 75.0
131.0 131.0 131.2 130.0 127.0 127.0 127.1 130.0 128.5 122.5 110.7 78.0
131.0 131.0 131.0 131.0 130.5 130.0 130.0 130.0 126.6 122.8 114.9 87.0
131.0 131.0 131.0 131.0 131.0 131.0 131.3 130.0 124.4 118.1 112.4 93.0
131.0 131.0 131.0 131.0 131.0 131.0 131.9 129.0 118.6 114.2 109.3 99.8
131.0 131.0 131.0 131.0 131.0 131.0 131.3 123.6 112.8 111.6 107.9 105.0
131.0 131.0 131.0 131.0 131.0 131.0 125.8 108.7 99.4 101.3 103.8 110.0
WOT Ignition Timing KF_TZ_VL
0x28E1EC
16x3
Row: 0x28E1C2
Column: 0x28E1E6
Conversion: x/10
stock values:
3.0 3.0 3.0
16.0 16.0 16.0
20.0 20.0 20.0
27.0 27.0 27.0
30.0 30.0 30.0
30.0 30.0 30.0
34.0 34.0 34.0
33.0 33.0 33.0
33.0 33.0 33.0
31.0 31.0 31.0
33.0 33.0 33.0
33.0 33.0 33.0
30.0 30.0 30.0
30.0 30.0 30.0
30.0 30.0 30.0
31.0 31.0 31.0
32.0 32.0 32.0
32.0 32.0 32.0
Limp Mode Pedal
0x28ACC6
10x1
Column: 0x28ACB2
Conversion: x/10
00 08 16 25 30 35 40 43 46 50Last edited by omhl; 04-22-2020, 05:10 PM.Tags: None
- Likes 3
