Hey everyone,
I'm trying to create an XDF to share with the forum with the binaries that we are reading from the MSS6X Flasher.
Just sharing some of my identifying findings using the MSS6X Flasher so far. Hopefully we can identify some more mappings! I am looking for servotronic comfort/sport addresses. pedal throttle map comfort/sport, ignition min(KF TZ VL MIN), WOT Fueling. I won't bother with cold start, o2 dtc stuff since ECUWORX tool can handle that.
Please share if you have any!
This is from 241E read.
RPM Limiter:
0x6062
1x8
16 bit
Columns: 0x6052
values:
8000 8300 8300 8300 8300 8300 8300 8300
TEMP RPM
0x6088
6x1
columns: 0x6088
row conversion: (X*0.1)-273.2 to degrees
-25.0 0.0 25.0 50.0 60.0 80.0
5000.0 6000.0 6500.0 7000.0 7500.0 8300.
Vanos Admission:
0xA862
16x12 table
16 bit
Row: 0xA82A
Column: 0xA84A
Conversion: X/10
stock values:
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 112.0 103.5 97.7
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 105.0 100.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 103.9 98.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 113.7 101.1 95.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 118.0 97.0 87.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.7 114.0 87.0
131.0 130.9 131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.6 116.0 83.0
131.0 131.0 131.0 130.0 127.0 126.0 124.0 124.0 128.1 124.0 115.7 83.0
131.0 131.0 131.2 130.0 127.0 127.0 127.1 130.0 128.5 122.5 115.7 83.0
131.0 131.0 131.0 131.0 130.0 130.0 130.0 130.0 126.6 122.8 114.9 92.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 130.0 124.4 118.1 112.4 93.0
131.0 131.0 131.0 131.0 131.0 131.0 131.0 129.0 118.6 114.2 109.3 99.8
131.0 131.0 131.0 131.0 131.0 131.0 131.0 123.6 112.8 111.6 107.9 104.0
131.0 131.0 131.0 131.0 131.0 131.0 125.8 108.7 99.4 101.3 103.8 108.2
131.0 131.0 131.0 131.0 131.0 131.0 122.0 102.0 94.1 96.0 101.5 112.0
131.0 131.0 131.0 131.0 131.0 131.0 121.9 100.1 92.2 95.8 103.5 120.0
Vanos Admission Heating (KATH):
0xABD6
16x12
16 bit
Row: 0xAB9E
Column: 0xABBE
Conversion: X/10
stock values:
131.0 131.0 131.0 131.0 131.0 131.0 131.0 126.8 123.0 109.0 98.5 97.7
131.0 131.0 131.0 131.0 131.0 130.9 129.3 124.0 119.0 110.7 100.0 100.0
131.0 131.0 129.0 125.6 123.0 120.3 117.0 119.0 119.0 116.7 98.9 98.0
131.0 131.0 127.3 120.5 117.1 115.8 114.4 117.2 124.8 117.0 95.5 95.0
131.0 131.0 127.3 120.4 117.0 116.0 115.0 117.3 125.7 117.0 91.0 77.0
131.0 131.2 127.0 120.0 118.0 116.0 115.0 117.0 125.0 123.7 106.0 77.0
131.0 130.9 129.1 124.0 118.0 116.5 116.6 119.1 127.0 123.6 111.0 77.0
131.0 131.3 129.7 125.0 118.0 117.0 117.6 120.6 128.1 124.0 110.7 75.0
131.0 131.0 131.2 130.0 127.0 127.0 127.1 130.0 128.5 122.5 110.7 78.0
131.0 131.0 131.0 131.0 130.5 130.0 130.0 130.0 126.6 122.8 114.9 87.0
131.0 131.0 131.0 131.0 131.0 131.0 131.3 130.0 124.4 118.1 112.4 93.0
131.0 131.0 131.0 131.0 131.0 131.0 131.9 129.0 118.6 114.2 109.3 99.8
131.0 131.0 131.0 131.0 131.0 131.0 131.3 123.6 112.8 111.6 107.9 105.0
131.0 131.0 131.0 131.0 131.0 131.0 125.8 108.7 99.4 101.3 103.8 110.0
WOT Ignition Timing KF_TZ_VL
0x28E1EC
16x3
Row: 0x28E1C2
Column: 0x28E1E6
Conversion: x/10
stock values:
3.0 3.0 3.0
16.0 16.0 16.0
20.0 20.0 20.0
27.0 27.0 27.0
30.0 30.0 30.0
30.0 30.0 30.0
34.0 34.0 34.0
33.0 33.0 33.0
33.0 33.0 33.0
31.0 31.0 31.0
33.0 33.0 33.0
33.0 33.0 33.0
30.0 30.0 30.0
30.0 30.0 30.0
30.0 30.0 30.0
31.0 31.0 31.0
32.0 32.0 32.0
32.0 32.0 32.0
Limp Mode Pedal
0x28ACC6
10x1
Column: 0x28ACB2
Conversion: x/10
00 08 16 25 30 35 40 43 46 50
RPM Limiter:
0x6062
1x8
16 bit
Columns: 0x6052
values:
TEMP RPM
0x6088
6x1
columns: 0x6088
Vanos Admission:
0xA862
16x12 table
16 bit
Row: 0xA82A
Column: 0xA84A
Conversion: X/10
stock values:
0xABD6
16x12
16 bit
Row: 0xAB9E
Column: 0xABBE
Conversion: X/10
stock values:
0x28E1EC
16x3
Row: 0x28E1C2
Column: 0x28E1E6
Conversion: x/10
stock values:
3.0 3.0 3.0
16.0 16.0 16.0
20.0 20.0 20.0
27.0 27.0 27.0
30.0 30.0 30.0
30.0 30.0 30.0
34.0 34.0 34.0
33.0 33.0 33.0
33.0 33.0 33.0
31.0 31.0 31.0
33.0 33.0 33.0
33.0 33.0 33.0
30.0 30.0 30.0
30.0 30.0 30.0
30.0 30.0 30.0
31.0 31.0 31.0
32.0 32.0 32.0
32.0 32.0 32.0
Limp Mode Pedal
0x28ACC6
10x1
Column: 0x28ACB2
Conversion: x/10
