Alpha N on MSS65_160E_ECUWORX TOOL
    Hello everyone
    I bought a license of Martyn's software from ECUWORX, I want to remove my MAFs on my M6E63,
    so I bought an IAT (intake air temp) probe, when I activate the "Alpha- N "on the software at Martyn "ecuworx" and I unplug my 2 MAFs,
    my M6 is malfunctioning
    Can you please help me to activate Alpha-N mode on my M6, I only want that, I don't want no other modification, I bought the ecuworx software but it does not work or badly
    Thank you
    The car still needs tuning, you can't just unplug the MAFs, enable AlphaN and expect it to run like stock!
      Yes Yes I suspect but what are the settings to make, right?
        Martyn
        I thought when buying your software I could run Alpha-N, I don't see what the point of integrating this option into your software if it doesn't work, that's what he made me buy your software, being able to run my ecu in alpha-n
          It's an experimental feature (as per the label in the software).
          If you want to enable AlphaN and for it to run like stock, you'll need to take it to a tuner.
            it's crazy you buy a software for 100 $ to activate the alpha-N and you sell it as experiment man, let me tell you that it is nonsense !!!
              It clearly states it's experimental before you even purchase a license. It also says in the 'how to' / FAQ that it's not a replacement for a proper AlphaN tune. A proper AlphaN tune (along with AlphaN enablement) will set you back a damn sight more than $100.
              https://www.ecuworx.co.uk/how-to/a-c...fication-tool/
              Enable AlphaN / MAF Delete (Experimental)
              Puts your vehicles DME into AlphaN mode. This is not a replacement for a proper AlphaN tune.
                it's not at all clear on your website, there is only this option that interested me, I paid it for nothing at all, if you want my opinion, go your way on this software
                  alpha-n is an experience, the pop and bang is an experience too, the transmission swap is still an experience the P500S in power in 400 mode dont work,
                  here is the truth about your tool, it is shameful !!!!
                    May I suggest you guys take this issue to PM or some other form of 1-on-1 communication, and let us know when it’s resolved?
                    2008 E90 M3 6MT
                    2011 E90 328i 6MT
                    RWD, slicktop, no iDrive
                      I need your help, I tried a lot of things but I can't recognize the DME with MSS 6X.
                      My OS is windows 11, I installed Ediabus, INPA, NCS, imported MS_65.prg and 10flash.prg, INPA is working fine and I can read the AIF.
                      I read the DME with MSS 6X and it says UNKNOWN! / unsuppported.
                      I used inpa and winkpf to find out that my dme version is 241E.
