It appears that the rear shocks need to be removed from the car to make any adjustments. Is there any way to adjust them while they're installed? Seems pretty cumbersome to remove the shocks whenever you want to adjust them. Thanks...
Is there a way to adjust rear Koni shocks while installed?
There's top adjustable Koni yellows, as well.Originally posted by BMWE46M3 View PostHmm, but I thought the shock needs to be fully compressed so you can change the setting?
For compress to adjust, you can just just undo the bottom bolt compress the shock, and adjust it while still attached to the RSM/chassis.
