2005 E46 M3 (6 SP) 110K miles
After the car warms up I am getting codes 171 and 175. When the car is hot is when the engine runs rough, If I shut off the engine and turn it on it seems to run fine again. The history is that I installed AA headers with pre cats only (new), replaced plugs, replaced coil packs, new intake boot , and new factory MAF sensor. I have verified that the pre cat O2 sensors are in the correct location on the headers.
I should also mention that the ECU was sent to AA for an update after the header changes.
