SMG issues: hesitation/stutter, missing gears, UPDATE: adaptation issues
Might be your clutch and throw out bearing etc. Could be any of those things.
Originally posted by Darbshaw View PostOP I have an actuator I'll let go for cheap. It's a used unit but worked perfectly on the car before I pulled it.
One smg lover to another
Originally posted by 0-60motorsports View PostHow many miles on the clutch? Or did you replace the clutch?
Again, the hydraulic pipes and others weren't opened that air got in, so why do you need to bleed the air out?
What knuckle?
I don't, I haven't said that I do? I simply said I ran adaptations from the beginning *once*. I don't see this being related to the issue of adaptation failing and the gear cannot be engaged code? (happy to be proven wrong though)
And yes, as BL92 mentioned the gearshift rod joint which is infamous for the 4th gear adaptation failure according to the internet.
Originally posted by big,JON View Post
I replaced all the springs, so 5 of them in total. 4 were good and the one behind the blind plug was broken in 3 pieces. I ran adaptations once through from the start including the actuator and clutch bleed and the rest I've just done the final adaption.
Before I go out and replace the actuator I'll recheck all the springs, GPS and wait on the arrival of the knuckle.
Thanks again for the help!
What knuckle?
- Likes 3
Why do you need to bleed the system if only replaced the roller pin / spring on the main shift rod?
Originally posted by big,JON View PostThanks oceanside.
I cleared the codes and ran the car today. It will engage 1st and reverse, but when selecting 2nd it flashes and returns to 1st, throwing the cog.
Read the codes, 48 - gear cannot be engaged. Cleared them and ran just the complete adaption (F3) again whilst everything was at operating temp and it failed at the same point with the same error.
What are the chances this could be the roller pin not installed vertically?
What are the chances the brand new GPS is faulty or installed incorrectly?
Could this still be the knuckle?
Any other thoughts as to what this might be?
Thanks oceanside.
I don't understand why or how bleeding the system will fix the adaptation issue when I haven't opened any of the wet/pressure systems?
Is there anything in the adaptation values that stands out to anyone?
Since I first wrote this thread I have changed all the appropriate springs, there was a broken spring behind the blind plug. I am adament that I put the roller pin back in vertically. I replaced the GPS with a brand new unit from Burkhart. I replaced the salmon relay with a new one.
Originally posted by big,JON View PostBig old thread revival here, can't believe it's been nearly 4 years since I started this journey and almost 3 years since the car has run!
I ran adaptation in INPA yesterday,
- The car is on stands but is level
- Doors, hood and boot were closed
- Handbrake was off
- Codes cleared
- Car was cold
- Battery was charged and on a charger
It passed the bleed actuator and bleed clutch first go. It failed the complete adaption at the same point probably half a dozen times - after the first cycle through gears 6th through 1st then reverse, then it would select 5th and fail. I got 2 error status':
- Shift too far out
- Switching travel too far out.
Fault code after failing is 83 Gearbox adaptation.
I am looking for a new knuckle, in the off chance that might be a reason for the failure.
I've attached the adaption values and adaption result.
Any ideas?
- Handbrake was off
- Codes cleared
- Car was cold
- Shift too far out
Any ideas?4 PhotosLast edited by big,JON; 02-24-2025, 04:34 PM.
