Summer's here and along with it the musty smell of my AC. Does anyone have a definitive solution to this problem? Tried various foam radiator cleaners including "Klima Cleaner Pro" and they dont last more than a few days. Short of replacing the entire AC unit is there any real solution?
Smelly A/C
This.Originally posted by Stack View PostMost smells come from left over moisture left in the vents.
Try running it on hot for 10 min through the vents
You should also leave the a/c "on" year round, if you're not doing so. The system will automatically turn the compressor on and off as needed.
During the winter the a/c will act as a dehumidifier to prevent moisture build up, as Stack said. Not to mention the refrigerant has lubricant that needs to be circulating, which will protect the seals.
- Likes 2
I read this issue early in the E46s life in a Service Bulletin long ago.
As described it’s moisture that gets accumulated in the AC drip tray. With the warmth it grows bacteria. A couple of things, make sure your drip hose isn’t plugged up. Next try and turn AC off a little bit before shutting off car (but fan on) so fan dries the water droplets/moisture. Next what the SI says is to spray a disinfectant spray (with a long tube hose)thru the left side floor vent. That’s basically to get the drip tray disinfected.
Hope this helps.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - Euro Bumper - Gruppe M CF Intake - Supersprint - M Track Mode
THis is the first time i heard about the drip pan. I'll try the left side floor vent method. THanksOriginally posted by oldFanatic View PostI read this issue early in the E46s life in a Service Bulletin long ago.
Hope this helps.
Are you catlessOriginally posted by yhp2009 View PostSummer's here and along with it the musty smell of my AC. Does anyone have a definitive solution to this problem? Tried various foam radiator cleaners including "Klima Cleaner Pro" and they dont last more than a few days. Short of replacing the entire AC unit is there any real solution?
