CA/LA Smog
Flashing back to your original factory file should be fine. BAR even said so, I think I remember reading in one of the posted links.
Pardon my ignorance on coding and tuning, but hypothetically if one were to reflash canned tunes back to the factory / default tune, this shouldn't create any issues with the CVN / checksum data correct? How about swapping ECUs with a virgin one?
Originally posted by thegenius46m View PostJust a heads up to the guys who aren't as computer savvy... ANY changes done to the dme will technically change the checksum. So yes even if you enabled sport mode memory, you technically will fail. Honestly I think its only a matter of time till this gets thrown out in court for being overly ridiculous. Anything modified in the dme that doesn't impact emissions in any way, shape, or form and cause you to fail smog. That includes even an smg tune where the shift parameters were modified on the dme side. SMG unit flash would be unrelated. But yes this is beyond ridiculous.
On a more serious note, this is no bueno at all. Curious to see how the next 30 days pan out for others (including other makes/models i.e. GTR's Evo's etc).
It's calculated. Exactly how it's calculated isn't entirely clear to me. IIRC @gpetersen found that if you brute force the checksum such that the calculated checksum is equal to the stock value, then the CVN is also correct. So it's either itself a CRC16 (of each half) with a different initial value and/or polynomial, or it's some sort of calculation that's done to the calculated checksum.
Probably wouldn't be crazy difficult to hardcode the program to return a valid value
I started all that in 2019 because there were rumors that MA was collecting CVN data to flag if it changed year over year .. donât think anything ever came of it, and also theyâre oddly lax about OBD2 emissions, exempting anything 15 years or older.
Mods/admins just deleted some political commentary and otherwise uselessly contentious posts. Please, everyone, let's remember why we're here.
If we can disable CRC check and modify the CVN and Cal ID to that of virgin stock tune parameters, this will be easy to bypass by spoofing. I'm thinking just mirror all these checksum parameters in the tune file (pic below) from the reference tables in the mss54 master page to match a virgin tune then just roll up lol. If its possible this will create some insane demand. Think of all the manual swap cars on hacked tunes.
Only other option is to do what repoman suggested which would be to modify unused sections of the tune to adjust the checksum calculation to match the virgin cvn number.
Forcing a CRC collision is relatively simple, that can certainly be done. 16-bit is small enough that it can be brute forced instead of doing the actual math to calculate a collision.
The only thing I did to my car in terms of software was a TTFS SMG tune way back when. Would something like this cause me to fail under these new rules?
Catless down pipes and burble tunes is what got us into this mess. TY newer BMW guys đ¤Śââď¸
- Likes 4
Anyone got the plug for smog somewhere in the Bay Area? Desperately need it asap as my registration expired
Originally posted by heinzboehmer View PostSounds like the perfect opportunity for someone to start a rent-a-dme service. They would just need a non-HP and an HP that they flash with the appropriate software for the car it's going to.
BTW I might offer some kind help/service if you're in dire need around the SF Bay Area region, let me know through PM, I'll try my best.Last edited by Samsonite79; 07-14-2021, 08:17 PM.
Originally posted by jet_dogg View PostSevan, ask your boy if there's any mention of year cutoffs specifically mentioned.Last edited by sev; 07-14-2021, 02:58 PM.
Yeah, I'm moving to Cali this fall. Great timing too, since my SAP just failed. If I was staying in Ontario I'd delete it, but I found a couple real cheap pumps off a salvage yard on eBay as replacement. Freaking Ontario just got rid of e-testing, now I have to go back to it
Originally posted by Tbonem3 View PostI might be one soon enough
