Yellow Tag (712) & Tie Rod Question
    Hi all.
    I'd like to throw on the "Yellow Tag" (712) rack onto a '02 M3 and am just wondering the following:
    Is this application basically "plug-and-play"/can I use the existing M3 tie rods or do I need 330 tie rods?
    (sorry for noob question)
    Thanks!
    Nope, you're good to go. You can leave your existing tie rods in places as well, no need for an alignment afterwards.
      Thanks for confirming!
        Yep use the M3 tie rods with it.
        You should also code the car (if year allows) for the CSL/ZCP rack. Otherwise DCS will trigger earlier on sharp turns.
          Yup I used m3 inner and outer tie rods when I did the swap
