Part number request
    Part number request
    Under the cabin air filter there are two rubber 90° drain spouts to drop water runoff to the right areas.
    Is there a part number just for these little guys or must you but the whole housing?
    My relocated sensors and the conduit I used make it so when I wash my car water ends up in my post cat O2's/ EGT sensors. This was likely the cause of a recent DTC I pulled.
    Wanting to buy and modify one of these if I can. When I pull the airbox in a few months I'll have better access for a permanent solution.
    Realoem.com
    Budget CSL MAP Conversion
      Awesome, thank you. Just found it on ECS after another small search, getting lazy...
