I have adjustable rear camber arms and I’m about to make some tweaks. It occurred to me that someone must have figured out roughly how much camber arm length adjustments correlate to changes in camber. The distance between the upper and lower mounting points would be pretty simple to measure, and it would just take a little trig to figure out the rest. Has anyone done this?
Rear camber adjustment measurements
Side note - adjusting camber also changes toe in the rear, so as long ad you are aware...
Youtube DIYs and more
I just use a string (distance from tire to fender) and make sure my distances are equal left to right both there and the length of the arms. Though I do so knowing I'm just playing around and will want a proper alignment when I'm ready (mostly to get toe correct; slightly in)DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I have a Longacre camber/caster measuring jig, although the level that came with it is malfunctioning. The jig is straight, though, so I'm using that with a replacement digital level/angle finder that is accurate within 0.1 degree. I also have toe plates, which you really need to combine with strings or some other method of measuring toe relative to the car itself and not just the two wheels being measured.
The TMS instructions do indeed have some rough estimates; that'll be good enough to get me in the ballpark before I fine-tune everything. Thanks for the tip! I'm at -2 degrees on the right and -1 on the left. It's kind of a shame, though, because my toe is spot-on...oh well.
