Mine had hardly any wear after about 100k kms. Nothing like that photo.
Yes smaller holes is the theoretical fix and I've not read of anyone having a failure with a modified pump disc (genuine redrilled or a Beisan one). That doesn't prove the fix but does support it.
That said, once moving I would not expect the free play to be much issue. The disc will "drag" as it's pumping and the tabs should always be pushing it around. I don't see how the disc would ever get ahead of the tabs and then end up being hit again. However the tabs do break and some discs like yours end up with significant wear. Perhaps if they start to wear a bit, it accelerates as the free play gets bigger.
Is this why Vanos oil pump fails?
I have a friend with a machining workshop here in Australia. Determining equal distance from centre is easy - the existing circular groove marks it - just need to ensure 2 new holes are precisely opposite. Original holes were 10.5mm. Drilled new 9.8mm holes - only a fraction of the play dry (so add some oil and the play will be virtually nothing).Originally posted by LatinSkllz View PostWho’s re-drilling the disc for you?
Vanos all reassembled and working like a charm.
It's very critical to have the new drilled holes be 180 degrees in line with the disk center, and equal distance.
Before the hub tabs broke, you should have the disk drilled with 2 new and smaller hole with about 0.010" clearance to the tabs.
No. I only put the last 14K on her - most of it being inter-state highway cruising (with some spirited back road driving here and there). However, it's a 'vert - unmolested and unlikely to have seen much (if any) track time. I'd imagine oil pumps on higher mileage and tracked cars would look even worse.Originally posted by sapote View Post
Were you the driver of those 54K miles, and what is the typical engine rpm range? I think more rpm changing in a quick pattern , rhythm, would cause more hammering on those disk holes. I would think the disk spinning speed is more stable than the cam hub as the regulated output oil pressure is stable.
Were you the driver of those 54K miles, and what is the typical engine rpm range? I think more rpm changing in a quick pattern , rhythm, would cause more hammering on those disk holes. I would think the disk spinning speed is more stable than the cam hub as the regulated output oil pressure is stable.Originally posted by poss View PostCloseup of my Vanos oil pump (after a paltry 54k miles).
That’s the leading theory. I’m of the opinion that BMW’s decision to remove the one-way valve at the pump outlet is what allows those accel/decel cycles to manifest. That is the major difference between the s54 and s50b32 and s62 vanos systems.
Closeup of my Vanos oil pump (after a paltry 54k miles). Note the clear indentation (which is also on the other side of the hole) caused by the tab on the spline impacting on the hole - adding at least another .5mm of gap that increases further the accel/decel impact of the tab on the hole. No wonder the tab eventually fails from metal fatigue1 PhotoTags: None
. Sent off for drilling today.
