ZCP vs CSL Wheel and Performance
  • rjsimz
    read through this whole thread...and it doesn't make wheel shopping any easier!
  • eXpensiveGears
    Originally posted by Rkymtnrider View Post
    Wow only $72000 you can get 2 m cars for that price😂😂
    haha sorry, meant 7,200. edited.
  • Rkymtnrider
    Originally posted by eXpensiveGears View Post
    I just stumbled upon these as well: https://www.litespeedracing.com/rs5 Around 15-16lbs per wheel and $7,2000 for a set. Based in LA, not sure on the mfg location.
    Does BBS make custom sets of the FI-R? those are in the 16-17lb range
  • eXpensiveGears
    I just stumbled upon these as well: https://www.litespeedracing.com/rs5 Around 15-16lbs per wheel and $7,200 for a set. Based in LA, not sure on the mfg location.
  • Obioban
    Originally posted by K-Dawg View Post
    The wheels with the arguably best combination of "quality" and "fitment" for the E46 M3 were brought to market by RAC Monolites. Even in the heyday of this platform, they could only muster limited interest and this was reflected in the numbers of wheels built.
    I recently saw mention that maybe they could be talked into another run... I might be interested in a set of staggered 18s.
    18" staggered RACs, you say?
    Click image for larger version  Name:	IMG_1819.jpg Views:	0 Size:	261.8 KB ID:	121477
    Sadly, I don't think another group buy is viable. 35+ plus people willing to drop $4000 on a set of wheels doesn't seem to be a thing at this point in the chassis' life.
    Maybe in another decade
  • Nate047
    Yea it's not like there are endless options. If you want 18s and you want forged in Japan, pretty much just get RIAs. Hopefully they will bring out some more size options soon for other wheels. Or you can get TE37s, places like Evasive can get you those. You can order Forgeline wheels in nearly whatever size you want, just be prepared for sticker shock. List price on the set of GTD1s Pete at Speed Academy put on his E46 was over $6k. If you can be okay with 19s for a street car, there's a ton more options.
  • Tbonem3
    I'd be in for 18" 9"et25-30 x 10"et20-25
  • K-Dawg
  • tnord
    it's not like I'm wondering why you can't get 14'' watanabes anymore. From the reaction to my "just throw apex's on it" sentiment, I was expecting at least a few new, off the shelf options for a strong, light, properly fitting wheel. Albeit expensive. That doesn't seem to be the case.
  • Tbonem3
    Ya, like when you get to 30 years old and you realize the ads/movies/products aren't geared towards you any more.
    You make do. Stay stock, go used or go chyna.
    You could do what Mr. Wolfe did and have a shop widen some ZCPs and make the ultimate CSL wheelset like 9"et28 & 10"et20.
  • jet_dogg
    Wow.
  • tnord
    I just went to BBS' website, and there are TWO wheel options for an E46 M3 in 18''. So everybody looking for these just has to scour the interwebs looking for a used set to refurbish?
    Rays wheels you might wait 6-12mos to receive your order. BBS wheels essentially have zero options with the proper sizing. I don't know much about titan7, but since they don't advertise where the wheels are mfg, I'm guessing it's china.
    Same with Bimmerworld TA16, and Apex forgings; made in china.
    forgeline doesn't appear to have any options
    HRE has been previously mentioned as not that good.
    Work wheels has a couple options, but they list 5x120 as "optional," which likely means unavailable. But plop down a fistfull of $1000s up front, then hope they show up within a year?
    I'm really struggling to find any options besides chinese forgings or scouring the used market unfortunately.
  • E46_M3_ZCP
    As a general formula, where:
    D = Distance from hub mounting surface to rim outside edge -->This is the value you want to use for comparison sake
    W = Wheel width in inches
    O = Offset in mm, for example et+38 is a positive offset of 38mm
    D = W divided by 2 minus O divided by 25.4, just be mindful of the units as wheel width is in inches and offset is in millimeters and 1" equals 25.4mm
    As Tbonem3 stated, you had it opposite since 8.5 et31 calculates to D = W/2 - O/25.4 = 8.5/2 - 31/25.4 = 3.0" which is the same as 9.0 et38 which calculates to 9.0/2 - 38/25.4 = 3.0"
    But calculated how you had originally stated it 8.5 et38 calculates to D = W/2 - O/25.4 = 8.5/2 - 38/25.4 = 2.75" which is different from 9.0 et31 which calculates to 9.0/2 - 31/25.4 = 3.25", and that's where the 1/2" further out number Tbonem3 stated above comes from
    *5mm spacer equals 5/25.4 or 0.20" and a 10mm spacer equals 10/25.4 or 0.40"
  • Tbonem3
    I'm not very good at this, but I think 8.5'' +38 is the same fit regarding fender 'flushness' as my 9'' +31?
    Opposite. A 9et31 would be a half inch further out at the fender than an 8.5et38.
    You'd put a 5-10mm spacer on an 8.5et38 wheel to get it to look similar to a 9" et31.
    There's a 6.35mm or 1/4" difference at the fender between 8.5 and 9" wheels (or any 1/2" diff wheelset). BUT, you do have to take the tire into consideration. If it's the same tire, it'll be stretched a little more and clear a little easier on the wider wheel. Also, a wider wheel will come into the well more and possibly touch the springs, esp progressive springs (tho that's not an issue on 9" but 9.5 et22 and greater I believe)
  • tnord
    Originally posted by T.J. View Post
    I went from 19” csl reps to 18” BBS RS-GT, which are forged and use titanium hardware. I couldn’t believe the weight difference when I was switching them out. These are 8.5” ET38 and 9.5” ET22, so they fit nice without spacers. I wouldn’t mind few more millimeters offset, especially up front with the free camber mod tucking them a little extra.
    Frankly, I was also expecting a big change in ride stiffness/comfort changing to 18s but it was not very dramatic, I guess due to the ps4s stiffness.
    On the looks, sure the CSLs rule but the period correct, motorsports look of these has grown on me. Only problem is the clear coat on the brushed barrels is starting to peel so I need to decide between polishing or trying to restore the brushed look
    and my 10'' +25 would actually have a little more room than your 9.5'' +22?
    The more I look into the BBS option, the more I don't like size options. The GT4s seem to need a hub ring so that's a no-go. These RS-GTs might get the offset right, and look the part, but I really like the fit of my 255/275 on 9'' and 10'' wheels.
