Hey guys, just recently I was pulling in to wash my car when all of a sudden I felt a weird rumble to my car when I noticed the idle of my car was uneven and whenever I revved it it started to sound like a boxer engine. I also noticed that the temps to the car were strangely very high for outside temp being around 75 degrees. There seems to be no coolant leaks and the car hasn’t ran for over a week until now. No spirited driving, just some highway driving and city driving. Don’t know what it could possibly be.
Engine sounding like Subaru idle
Pulling plugs and all of them minus cylinder 6 are drenched in oil. Can that be a sign of a bad head gasket?Last edited by erickhoyos; 08-15-2021, 01:16 PM.
I would have thought if the plugs are oily it's a bad seal, either a piston ring or valve stem seal, alternatively the PCV could have swallowed some oil somehow and it following the path of the intake into the combustion chamber. The head gasket is for the water jackets and coolant so I don't see how that would make the plugs oily?
Regards
Spark plug aluminum tubes sit higher than the valve cover, so leaking grommets or leaking spark plug tube seals can not contribute oil to spark plugs. Run a wet vs dry compression test to see if you got ring issues. Do you have colored smoke out of the tailpipes on cold start? Valve seals might be going.
Youtube DIYs and more
1. Spark plug aluminum tubes sit higher than the valve cover. True, however this is not a lake but oil spraying everywhere, and a leaky valve cover gasket will let oil leaking into the plug hole.Originally posted by mrgizmo04 View PostSpark plug aluminum tubes sit higher than the valve cover, so leaking grommets or leaking spark plug tube seals can not contribute oil to spark plugs.
Unfortunately I didn’t take any pics, the only best way I can describe it is that the threads were covered completely in oil and a little bit of the tip of the ignition coils had oil too except cylinder #6. As of right now there hasn’t been any smoke coming out of the exhaust, I have yet to check the spark plugs again for oil. I’ll update next week when I get a chance.Originally posted by sapote View Post
Pics of the plugs? The tips are covered with oil but the body above the threads are dry? And you don't see blue smoke from burning oil?
So the oil got into the holes, and when the plugs were removed, oil flowing down and covered the plug threads. But how did the oil get into the plug holes as I don't think all 5 plugs were loose in there?Originally posted by erickhoyos View Post
