Cleared codes with OBD scanner, now car won't start. HELP!!!
Now that you have INPA, you can clear any codes now without worrying. For me INPA is my go to scanner for my M3
It was an issue with an older version on the Foxwell scanner. I had to realign the EWS. I ordered a cable and installed INPA, worked like a charm. Thanks all.
All good advice. I am going to go the INPA route and get that downloaded and set up.
Yes ews is nice to have especially if you're not parked in a garage all the time. It's easy to beat the tumblers even with the Lazer cut. It's getting past the computer that's tricky to thieves. You remove that and you're making it that much easier to steal. Plus you're not 100% sure that's your issue. Try a resync like stated or get it professionally diagged. If you're not familiar with cars you can cause more problems trying to delete the ews, and then it's just more of a headache for the actual mechanicOriginally posted by heinzboehmer View PostSure you can do that too. It requires modifying the software in your DME though.
MSS54 and MSS54HP XDFs . Contribute to saildot4k/MSS54-XDFs development by creating an account on GitHub.
or using a (paid) tool:
First and foremost, ECUWorx offer no warranty of any kind, we are not liable if you break your car by incorrectly flashing your ECU/DME. You do so at your own risk! You will require the following: A copy of the MSS5x Binary Modification Tool, available here A fully charged laptop and a copy of BMWFlash or MSSFlasher. Available from here: BMWFlash or a copy of from here: MSSFlasher A FTDI based OBD2 diagnostic cable such as a BMTechnic cable / BM or a KKL Vag-Com cable. yIf you don’t have one, you can buy one from here A trickle charger
Resync is probably the simplest option.
Sent from my SM-G996U1 using Tapatalk
I saw something on Youtube about an EWS delete, any experience with that?Originally posted by heinzboehmer View PostYeah unaligned EWS will do that. Start up normally and then immediately die. Like less than a second between letting go of the key and engine dying.
This is for an x5, but the process is probably very similar for the e46: https://xoutpost.com/bmw-sav-forums/...code-4a63.html
If you can't get the scanner to work, INPA or DIS can do the realign.
No other service.Originally posted by Cubieman View PostDid you happen to perform any service other than simply reading codes? Did you unplug any sensors by any chance?
Perhaps if you did an oil change you forgot to plug the TPS sensor back in near the the oil filter housing.
It turns over like it's going to start then dies immediatelyOriginally posted by TropicalM3 View PostNot sure if that scan tool can do it, INPA does. What exactly is the car doing? I'm only guessing here.
Is this something that can be done with a scan tool?Originally posted by TropicalM3 View Post
The EWS system is the cars security system, where the key has to transmit a code to the car for it to start. Maybe that is out of sync.
The EWS system is the cars security system, where the key has to transmit a code to the car for it to start. Maybe that is out of sync.Originally posted by Mikehest22 View Post
What does this mean?
What does this mean?Originally posted by TropicalM3 View PostEWS? May need to re-align.
