Kind of a shot in the dark here, but while doing some routine maintenance I noticed my transmission was covered in oil. I assumed it was a leaky drain plug that just wicked everywhere so I cleaned everything up, used some thread sealant on the plugs, and filled with ~2L of new fluid. Lo and behold, I can see fluid accumulating again at the joints where the transmission is bolted together.
I can't see a clear definite starting point, it just looks evenly distributed across the gasketed area and pools at the bottom where the red arrows are.
Has anyone heard of this? I don't think it's losing enough to cause an issue with low fluid level, but is just kind of annoying that it attracts dirt over time and I would like to fix it if that's even feasible.
Thanks
Pic below of the before I touched anything.
And after cleaning
After cleaning (side view)
Thanks
And after cleaning
