  • Obergoose
    Bubba, here's a chart of P/Ns to reference if you're trying to source this amp. Data is derived from RealOEM.com and my notes about which units don't have coax is only an assumption based on the fact BMW still sells 2 versions of this unit - 304 & 102.
    E83 (X3) & E85 (Z4) Models Begin End Note
    65126923900 9/2/2002 7/5/2002
    65126930046 9/2/2002 9/24/2002
    65126936087 2/20/2003 5/27/2003
    65126932417 2/20/2003 2/5/2007
    65126936952 4/25/2003 8/22/2003
    65126938189 9/1/2003 9/29/2004
    65126946727 3/1/2004 4/1/2005
    65126963304 3/18/2005
    65126974231 9/1/2005 5/11/2011 No Coax
    65129125751 3/31/2006 6/23/2007 No Coax
    65129138102 9/18/2007 No Coax
    65129138102 Models used in...
    2010 X3 xDrive30i
    2009 X3 xDrive30i
    2008 X3 3.0si
    2007 X3 3.0si
    2008 Z4 Coupe 3.0si, M Coupe, M Roadster, Roadster 3.0i, Roadster 3.0si
    2007 Z4 Coupe 3.0si, M Coupe, M Roadster, Roadster 3.0i, Roadster 3.0si
    2006 Z4 Coupe 3.0si, M Coupe, M Roadster, Roadster 3.0i, Roadster 3.0si
    65126963304
    2006 X3 3.0i
    2005 X3 2.5i, 3.0i
    2004 X3 2.5i, 3.0i
    2004 Z4 2.5i, 3.0i
    2003 Z4 2.5i, 3.0i
    2005 Z4 2.5i, 3.0i
  • BubbaTree
    Brian,
    Your research skills are impeccable! My Touring received the gift of Navigation (along with H/K with BavSound speakers) recently, but I haven't buttoned it all back up to post about it
    Anyways, I toyed with this idea and I think I have a better solution for you -- the E8x "DSP Amplifier" (Top HiFi) is a similar form factor to the E46s and it uses exactly the same harness connector, which should eliminate the need to re-wire the system, you just have to re-wire the connector.
    E8x DSP:
    Pin assignments at plug connector X10266
    1 A Signal, rear left speaker - Subwoofer, left
    2 A Signal, rear left speaker + Subwoofer, left
    3 A Signal, front left woofer - Woofer, front left
    4 A Signal, front left woofer + Woofer, front left
    5 E Terminal 30 Fuse F102
    6 -- Not used
    7 -- Not used
    8 -- Not used
    9 E Signal, AF radio, front right + Radio
    10 A Aerial switching signal Aerial diversity
    11 A Signal, front right tweeter + Tweeter, front right
    12 A Signal, front right tweeter - Tweeter, front right
    13 A Signal, rear right mid-range speaker + Mid-range speaker, rear right
    14 -- Not used
    15 -- Not used
    16 -- Not used
    17 E Signal, AF radio, front right - Radio
    18 E/A K-bus signal K-bus connector
    19 -- Not used
    20 -- Not used
    21 A Signal, rear right mid-range speaker - Mid-range speaker, rear right
    22 A Signal, front right woofer - Woofer, front right
    23 A Signal, front right woofer + Woofer, front right
    24 A Signal, rear right speaker - Subwoofer, right
    25 A Signal, rear right speaker + Subwoofer, right
    26 M Ground Ground point
    27 -- Not used
    28 E Mute Cellular telephone
    29 E Signal, telephone AF + Cellular telephone
    30 E Signal, AF radio, front left - Radio
    31 A Signal, rear left mid-range speaker + Mid-range speaker, rear left
    32 A Signal, rear left mid-range speaker - Mid-range speaker, rear left
    33 A Signal, front left tweeter + Tweeter, front left
    34 A Signal, front left tweeter - Tweeter, front left
    35 -- Not used
    36 -- Not used
    37 E Signal, terminal 50 via vehicle immoblizer Cellular telephone
    38 E Signal, terminal 50 via vehicle immoblizer Radio
    39 A Signal, front left mid-range speaker - Mid-range speaker, front left
    40 A Signal, front left mid-range speaker + Mid-range speaker, front left
    41 A Signal, front right mid-range speaker - Mid-range speaker, front right
    42 A Signal, front right mid-range speaker + Mid-range speaker, front right
    E46 HiFi (Non HK and HK):
    Pin assignments at plug connector X605
    1 A Signal, rear left speaker - Left rear speaker
    2 A Signal, rear left speaker + Left rear speaker
    3 A Signal, front left woofer - Front left speaker
    4 A Signal, front left woofer + Front left speaker
    5 E Terminal 30 Fuse F41
    6 A Positive activation, subwoofer Subwoofer box
    7 A Signal, subwoofer switched Subwoofer box
    8 E Signal, AF radio, rear right + Radio control unit
    9 E Signal, AF radio, front right + Radio control unit
    10 A Aerial switching signal Radio control unit
    11 A Signal, front right tweeter + Mid-range speaker/tweeter, right
    12 A Signal, front right tweeter - Mid-range speaker/tweeter, right
    13 A Signal, rear right tweeter + Right rear high range speaker
    14 A Negative activation, subwoofer Subwoofer box
    15 E Signal Spatial sound Switch center
    16 E Signal, AF radio, rear right - Radio control unit
    17 E Signal, AF radio, front right - Radio control unit
    18 -- Not used
    19 A Speedometer (A) output signal Subwoofer box
    20 E Speedometer (A) output signal Instrument cluster control unit
    21 A Signal, rear right tweeter - Right rear high range speaker
    22 A Signal, front right woofer - Front right speaker
    23 A Signal, front right woofer + Front right speaker
    24 A Signal, rear right speaker - Right rear speaker
    25 A Signal, rear right speaker + Right rear speaker
    27 -- Not used
    28 -- Not used
    29 E Signal, AF radio, rear left - Radio control unit
    30 E Signal, AF radio, front left - Radio control unit
    31 A Signal, rear left tweeter + Left rear high range speaker
    32 A Signal, rear left tweeter - Left rear high range speaker
    33 A Signal, front left tweeter + Mid-range speaker/tweeter, left
    34 A Signal, front left tweeter - Mid-range speaker/tweeter, left
    35 -- Not used
    36 -- Not used
    37 E Signal, AF radio, rear left + Radio control unit
    38 E Signal, AF radio, front left + Radio control unit
    39 A Signal, front left mid-range speaker - Mid-range speaker/tweeter, left
    40 A Signal, front left mid-range speaker + Mid-range speaker/tweeter, left
    41 A Signal, front right mid-range speaker - Mid-range speaker/tweeter, right
    42 A Signal, front right mid-range speaker + Mid-range speaker/tweeter, right
    Thanks!
    -Ted
    Guys, I don't understand the first thing about this technical stuff ... But I want one for my '03 'vert!!
    Thanks for keeping BlueBus alive and growing!
  • Obergoose
    The price of these amps on eBay is what made me give up on the idea. They also don't all come with the digital input connector as it was phased out, but I can and have retrofit it onto this style amp successfully (literally just soldered on an Amphenol brand connector from Mouser). I will also add that the quality difference from digital to analog on these amps is less dramatic than with the older variant of the DSP amplifier which tells me that they improved the ADCs in the amplifier. Finding appropriately sized speakers that match the impedance and output power expected is probably the most difficult part of this retrofit.
    The Siemens CID radios are indeed more reliable, but I've found them to be more stringent about what they let you do, at least on the BlueBus side of things. Users on the Zroadster Forum (German-based Z Fourm) found out the hard way that these radios don't allow you to change the volume while on a phone call, unlike the BM5x radios. I've temporarily worked around this limitation, but it's going to take some more work to make it right.
    Speaking of prepping the misses, you're right about the Touring -- I'm very close to sourcing a full M3 drivetrain for it, as my replacement to my beloved M3. The M3 is on stands waiting for a welder to come around and slap my CMP plates in, and then it'll be for sale -- unfortunately a Coupe is difficult to use when you have three infant children.
    I've sold/shipped over 1800 units in the past year and a half -- WOLFN8TR just got in on the batch that I started in late January and shipped in late June.
    Thanks!
    -Ted
    Good copy on the coax connector. I just ordered this amp. Good to know about the volume issues with the CID. I'll watch for this and report my results. As you've been so generous as to keep the project open sourced, I'll see about making some commits to bugfix these sorts of things as time allows.
    Best of luck with that swap, not that you'll need it with your skillset. That sounds like a massive undertaking but you're absolutely right about coupes and kids... those extra doors really take the hassle out of swapping car seats.
  • VisorM3
    Thanks!
    -Ted
    Awesome! Well I'm on the list, can't wait!
  • t3ddftw
    Originally posted by Obergoose View Post
    Good stuff! I'd wager that as soon as you've got that wagon put back together, it'll be apart again
    Excellent tip on this model amp! I'm sourcing now... looks like these are a fair bit rarer than others. Apparently, many Z4 owners had theirs ruined by rainwater (poor trunk design) so will need to watch for this on the used market.
    Analysis on these units is light but so far not seeing anything that would disqualify this for use in the E46. All in all, I think this'll work.
    Commonalities to H/K amp:
    • Same 2-pin connector ✓
    • 10+2 speaker system ✓
    • Similar dimensions ✓
    Benefits over the H/K amp:
    • Two, built-in, high power (30v) output stages for the sub amplifier (vs. the auxiliary unit for 6x9s)
    • True 10-channel
    • THX certified (for whatever that's worth)
    • DSP
    Drawbacks:
    • AMP is EQ'd for entirely different vehicles
    • Speaker impedances likely different (TBD)
    • Finding correct spec aftermarket speakers that actually fit an E46
    In an effort to avert the reliability issues with the BM53 Becker radios that came standard in E46 nav cars, I also have the SiemensVDO CD-82 CID unit which came equipped in the same vehicles as your recommended amp. This unit has some additional features which may or may not work including:
    • HD radio (via built in IBOC module)
    • A buffering circuit (which blends FM/AM radio changes)
    • RDS data improvements
    Better prep the misses for a few more project weekends . More to come...
    Originally posted by VisorM3 View Post
    How did you get it? I thought they were backordered until October
    Thanks!
    -Ted
