Originally posted by T.J.
Based on what I understand: if you are increasing spring rates on your car (and changing "frequencies") you'll probably need to increase damping on an Ohlins R&T setup to handle higher rebound forces the spring generates. Unless for some reason you added weight to your car in the equation. On the other hand, controlling compression events with a combination of tire psi, damper settings, spring rates, swaybar stiffness, etc. with an approach that optimal for the track and available traction is a bit more complicated. So, it likely just boils down to "did that feel better?" or "was that faster?"
I'm still curious to learn what folks are setting the dampers at using the original Ohlins springs for track use - focusing on how you want the car to handle low (shaft) speed compression events.
