I currently have kw clubsport suspension on my car. Looking to replace my kw camber plates for vorshlag to get caster adjustability. When on the vorshlag site, which strut style option do I choose ?
TIA
Clubsports are not too common outside of the UK/EU. I'd try and call/email Vorshlag as they are pretty knowledgeable. The clubsports have a linear spring, so you need to know the barrel diameter of the spring.
So vorshlag replied “Steven, those Clubsports use the same shaft profile that the V-Series use.”
Sent in my order and now we wait
The V3s and clubsports might use the same damper, but the spring perch on the camber plate side is a completely different diameter. Did they recommend the camber plate that is for the OEM strut, which is the same ones used for the V3s?
