Anyone replace their hard steel lines and have a DIY or guidance?
Both rears rusted at the junction between the hard line and rubber hose and leak. I repaired the passenger rear at the junction, but I failed today trying to flare the driver's rear. Will replace both rear lines, fronts too if in bad shape.
Bought two 5' copper brake lines, not sure what length lines I need. Advice on lengths for all four corners?
Also is there a midway junction that serves the rear vs replacing all the way to the master/pump?
Sent from my SM-G960U using Tapatalk
