Luke's 2002 M3 Intro
    Hi all,
    I recently joined this forum and am relatively new to the world of E46 M3 ownership. I was sad to see the death of M3forum.net even though I was not a part of the M3 world at that point. Many thanks to Obioban and others for taking the time to preserve the content from M3forum.net.
    I purchased my M3 in September of 2020 and my love of the car has been growing over the past year. The S54 is such a gem and couldn't be more different than the S62 in my E39 M5. I've had the M5 for now seven years and will say that both cars complement each other so well. The personas of each are so different that it makes it an absolute blast to drive them back to back. I'm still pinching myself that I own both of my childhood dream BMW M cars. I will say that I've been spending more seat time in the E46 and less in the E39 since bringing home the M3. It's just too fun to rev that S54 through it paces.
    The M3 is a 2002 Carbon Black over black coupe factory six speed manual with just over 72k miles. I'm located in the Boston area and flew down to Orlando to pick it up and drive it back up to New England. I'd describe the car as very "OEM+" in its current set up. Everything is factory except for Fabspeed headers, and Borla mufflers (factory section 1 & 2). Overall, I really like the sound but plan on replacing the resonators to alleviate some of the mid-range "rasp." The previous owner tackled some of the pain points of the E46 which originally drew me to this particular example. The subframe had been reinforced as well as the common VANOS failure points addressed with Beisan Systems parts including their anti-rattle kit for good measure. Over the past year, in typical E46 M3 fashion, I have had to deal with quite a few common failure points including a leaking CPV, VCG, and lower timing chain tensioner. At one point I had three separate oil leaks but all three were relatively easy to diagnose and correct. I also dealt with some odd electrical issues that, through research, determined are somewhat common on the E46 with age. These included a failing ignition switch, starter motor, instrument cluster, GM5 and door lock actuator. Never fun but at least the car should be fairly bulletproof at this point.
    Future plans for the M3 include replacing the factory struts with Koni Yellows and Dinan lower springs as well as refinishing the ZCP wheels (Style 163M) that came on the car. I'm also planning on having the front end (bumper, hood and fenders) resprayed as there is quite a bit of road rash from over the years.
    Super stoked to have joined the M3 community and glad to have found this forum!
    Looks super clean, nice grab!
        Welcome
        FYI, refinishing the zcps is rarely successful. Unless the shop is going to use the proper glasuirt paint or some other, quality match. Do not powdercoat. Has to be paint, with clear.
          Oh you found us.
          XD
          2005 BMW ///M3
          Black6MT Daily
            Congrats and welcome to the club
              Welcome!
              Completely agreed on the e39 vs e46! They're remarkably different experiences, for being so superficially similar. Excellent compliments to each other. Also interesting, I feel like they moved away from that in e9X/e60-- those two are much more smaller/larger versions of the same concept.
                Beautiful M3 man, welcome to the club. I too have a Carbon Black so I'm stoked at the simplicity of your current setup. When our cars are clean they're stunning.
                  Good to see you at the dark side Luke! Super jealous of that wheel
                    The M3 received both cosmetic and mechanical TLC just in time to be stored for the winter. The previous owner had the front bumper re-painted shortly before I took possession of the M3 and whoever did the work, frankly did a sub-par job. Within 1,500 miles the bumper was chipped far worse than cars I've seen with 100k miles and original paint. This was the perfect excuse I needed to go all in and talk myself into biting the bullet and having the full front end resprayed (bumper, hood and fenders). A friend of a friend completed the paint work and absolutely knocked it out of the park with exceptional paint match (somewhat difficult with Carbon Black). Its amazing just how better and more aggressive the front end looks with the new paint. I also had a new front windshield installed at the same time.
                    The struts and mounts were also a bit tired being original at 73k miles and I wanted to replace with an "OEM+" set up. I decided to go with Koni Yellows paired with Dinan springs and Turner Motorsport adjustable front and rear sway bars with new associated hardware. I'm completely blown away at how much more composed the car is mid corner with significantly less body roll yet a more compliant ride over bumps with the Konis. Its completely transformed the car and exactly what I was looking for out of a suspension upgrade.
                    Unfortunately, I only had the chance to drive it twice after the work done before having to store it during these long New England winters and I can't wait to log more miles in the spring!
                      Hey I know those cars in your OP 😛
                      Where do you store your car (assuming that’s your car storage facility in the last post)? I need a spot or two as well ..
                        Hi👋
