There is an easy way to connect everything in a functional manner:
The driver's side brake duct (#4) serves as the intake for the factory system. That's the starting point.
In the diagram, #20 tube gets cut down by an inch or two. Orient the tube so it fits back in the duct hole by 180 degrees from factory (its cut on an angle, you want to install with the long end towards rear of the car so as to catch the air). I think you'll need to grind down a plastic locating key.
Squeeze the upper portion in your hand to fit over the triangular portion of the snorkel. The bottom portion fits back in the hole of the duct.
On the duct, there is a bulbous protrusion designed to direct clean air into the factory system. Its not visible in the diagram. Cut the end of the bulb off you have another side duct, essentially.
Get 3" neoprene air duct (single layer) from Pegasus Racing meant for brake cooling. 3 ft length is needed. Connect air duct to your newly formed "side duct," and the other end to the intake of the CSL airbox, the intake downstream from the flap. You'll want to cut away the wire of the air duct for a good seal. 2.75" air duct would be perfect but I didn't find any in that size.
With the factory powersteering lines, you aren't going to have much room to run that 3" duct so be prepared to smush it, tie it away, etc. Interference with the alternator pulley is likely. I did away with the factory lines so it fits well.
For those to whom its applies: some vehicles have blanking plates on the rear of the factory brake ducts (visible from the wheel wells). My driver's side came with a partially closed blank and passenger side with a full blank (nothing can pass through). You can swap plates to direct maximum air into the driver's duct which feeds your airbox.
