FYI: Wiper refills are NLA
    61617010247 is still available, right side 61617010248 is NLA. Not sure for how long its been as I usually replace them once a year.
    What's the next best option here?
      Just buy two lefts and trim right to size, a lot of refills are like that.
        I feel like you should be able to buy a 50ft spool of this stuff
          FCP has Bosch refills - https://www.fcpeuro.com/products/bmw...40i-3397033365
          It does not need to be an OE part, OEM still works.
            These are for a 5 series, do they work on our OEM blades?
            Sent from my Pixel 5 using Tapatalk
              They're all the same, trim to size.
                It’s shows 2001-2006 M3 as fitment in description directly on their site. Saying trim to fit length.
                • 2006 BMW M3 Windshield Wiper Blade Refill
                  For standard style wiper blades, trim to length
                  Thanks boys.
                    Looks like they're NLA from FCP. Pelican Parts still has them, though.
                      Can't believe this man.
                        I noticed that too. I got these from FCP until the OEM refills make a comeback. Windshield Wiper Blade Set - Bosch 3397001394 | FCP Euro
                          will they fit? or you are just gonna pull rubber "refills" out them?
                            I removed the OEM ones out for now and just installed the Bosch blades for now. I went on a little road trip with my car and I wanted clean blades. I'll probably do what Jet_dogg said and trim the Bosch replacement ones.
                            I wonder if the OEM refill blades for a newer BMW will fit once we trim?
                              Most of refills are the same basic design so you can just find ones that are long enough if you have the older style blade and not the evo.
