P0011 cam position bank 1 cel code
    What am I looking at here a bad sensor? Car still rips no misfiring. Have not had any engine work done.
    Sent from my Pixel 3 XL using Tapatalk
    The p0010, p0011 through to p0015 will say camshaft, but are codes indicative of a failing vanos solenoid.
    See:
      See:
      http://www.beisansystems.com/procedu..._procedure.htm
      Thanks for the link.
      Looks like I got another project to do. Wonder if I should just do a full vanos rebuild also
        Probably.
        I didn't because my valvetrain looked absolutely perfect. Like zero wear at the disc/tabs. I should have done Besian's chain guide, but forgot. I did his solenoid and the sealing plate o-rings along with a valve adjustment. Details are in my build journal (2002 car) if you're interested.
