PSS10 are progressive rates of 340/565
Sometimes I agree with you, other times I don't - and this is one of those times you seem way off the mark. You're just 'upgrading' for the sake of upgrading without keeping OP's use-case in mind.
There's no need to convert PSS10 springs to a linear setup for most people, and Ohlins are not a fundamentally better setup for an extra $1000. Yes i've owned both, and for a street car i'd prefer the PSS10 to an MCS. The Ohlins just aren't the best for this car. Sorry but the premium damper hype is grossly overrated for anything but track use, and should not be the defacto recommendation. And flat ride is not nearly as important as valving. It's hilarious to see people saying keep stock brakes (MEH at best) but not suggesting that Eibach/Koni is the perfect suspension solution for this guy.
I'd much rather see the 996 kit be recommended because it will even improve ride quality due to the decrease in unsprung weight. Don't know why $3000-6000 dampers that will be exactly what he doesn't want should even be part of this discussion.. jfc.
Originally posted by Tbonem3
View Post
View Post
