DSC/TPM/Yellow Brake Light After Steering Rack Change
    Just swapped my rack over to a yellow tag/712 rack with new tie rods. On my way to the alignment shop (maybe 8 miles into my drive?) i got a trifecta of lights that popped up on the dash - DSC, TPM & yellow 'brake' light. Has this happened to anyone after changing steering parts? Steering angle calibration needed?
    Thanks!
    Steering angle calibration most likely
    Sent from my SM-G996U1 using Tapatalk
      Hi guys Does anyone know 100% if you need to code the dsc module ???after install 712 rack on left highway curves dsc cut throttle and only at left turns ...i try on right curve same km nothing....anybody can help? Sent from my LM-G900 using Tapatalk
      On the forum first page.
        Reset steering angle sensor and all is good now.
          What did you use to reset it?
