Track Toolkit?
    Track Toolkit?
    Trying to put together a separate toolkit to take to the track so I don’t keep having to scavenge the garage tool chest each time.
    Any recommendations for off the shelf tool kits where the case is decent and sockets don’t fall everywhere?
    Knipex makes nice tool bags (a lot of other brands do as well) but for what you are talking about I would purchase some short socket rails with interchangeable inserts and put them in the bag to keep the sockets organized. Wrench rolls, bag/backpacks with adjustable or expandable tool holders etc. Check out KCtool.com You can definitely find something there.
    Ahh you are looking for single set to do it all. That will be difficult. You can really pare down what you actually need and buy the products individually otherwise you are just going to be buying extra stuff you don’t need. Took me a little while to shift from quantity to necessary. I carry in a Knipex bag:
    1 socket holder with Williams 6, 8, 10, 12, 13, 16, 17 (protected socket) + sockets needed for the brakes you run and some torx)
    Knipex Side Cutters (for plastics etc)
    Knipex Plastic Rivet Tool
    Knipex Pliars
    Williams 3/8 extensions-short and medium (for yanking on coils)
    Milwaukee M12 Stubby with Williams 1/2 adaptor
    Magnetic Pick Up Tool
    Sylglide
    Silicon Spray
    Antiseize
    Goggles
    Brake Cleaner
    Shop Towels
    Wrench Roll
    Tire Gauge
    Pyrometer
    Caliper spreader
    Dead blow
    1/2 Torque Wrench
    Turbo Towels
    A lot of zip ties
    Two extra ignition coils
    Extra Pads
    I’m sure I am missing something but that setup has yet to let me down yet.
      ^ plus one throttle position sensor.
      I don’t sweat try to have everything I could possibly need— there’s always someone to borrow a tool from in a pinch.
        Ideally, just a miscellaneous tool kit for me would contain:
        knipex cobras, pliers wrenches (i don't know what the plastic rivet tool is no such thing)
        proto, wright, or hazet ratchet and socket set in aforementioned sizes with wobble extensions
        hazet torx and etorx sockets
        wera torx screwdrivers
        mayhew hook/pick set
        deadblow mallet i like halder, nupla and trusty cook
        makita xwt14z or milw mid torque
        safety seal tire repair kit
          Basic 100+ tool set. Bag of pliers. Some extra fluids. Tire pump.
          But mostly AAA car tow. Most of the time if something goes wrong, unless it's something simple, I call it a day and tow it.
            Noting that AAA doesn't like tows from race tracks. As in - they will ask the tow truck driver if it is a track. If he says yes - they will (by policy) refuse the authorization. That is from a tow driver who has done a lot of calls to a track. The tow driver may say its not a track just to get the fee - but.... Some tow drivers won't go on to the grounds, knowing the issue.
            I know people that have gotten a cheap local tow to 5 miles away from the track and then called AAA.
              I've not had that experience out here in California. Guess I'm lucky.
                Agreed. The actual parts and fluids are more important than the tools. The guys with the $500,000 trailers usually have a set of tools you can borrow. They are also good friends to make haha.
                  Pretty good starting list above. I got a set of Milwaukee packout boxes to organize my tools, one of the best things I've done. They stay in the trailer unless I'm driving to an event, in which case they're easy to grab and toss in the trunk.
                  I also have what is now a mature checklist I use before going to any event. I'll share with anyone that wants it for a starting point, just PM me an email address and if you prefer Excel or pdf.
                    Add:
                    5mm & 6mm hex bits
                    T10,15,20,30 bits
                    Jack stands (non- HF ones... )
                    Really need to answer...what are you willing to do at the track? That will guide what else you need to bring.
                      Add:
                      5mm & 6mm hex bits
                      T10,15,20,30 bits
                      Most of the time I just do brakes and wheels. But on occasion done things like o2 sensors, tps, coils, minor suspension stuff, etc.
                      I’m not swapping clutches at the track or anything. There is a limit of what i’ll do to save a weekend. If its
                      Ended up picking up the Dewalt socket set from costco. Seems decent but I don’t need all the SAE crap.
                      I have a tool roll for wrenches, pliers, screwdrivers etc. But the socket rails I have are too long to pack out.
                      Startup Idea: Car make/model dependent toolkits. Only buy what you need!
                        SAE crap is the bane of getting a good, compact tool set. It’s really amazing that nobody seems to offer a set without it.
                          lol...so true! But we're in 'Murica...find a buddy who does home stuff. He'll use all of the SAE stuff.
                            Packout is excellent, as are the drawers.
                            Hahaa good one, people are too cheap to buy good tools.
                              Here’s that I have in my toolbox…
                              Combo short 1/4 & 3/8” ratchet
                              1/4” and 3/8” extensions
                              1/4 drive sockets 8mm to 13mm
                              3/4” drive 14, 16-19mm, 24mm sockets
                              2x 17mm sockets
                              E10-E14 sockets
                              T10,15,20,30,50 bits
                              4mm to 6mm hex bits
                              7,8,10,11,13,14,16,17,18,19mm ratcheting wrenches
                              Adjustable wrench
                              Ratcheting screwdriver w/bits (Phillips, flat of varying sizes
                              Breaker bar
                              Torque wrench
                              Battery impact
                              Small impact
                              Pad spreader
                              Air gauge
                              Pry bar
                              Crimped
                              Multimeter
                              Trailer box has:
                              BFH
                              Jack stands
                              Shop towels
                              Brake cleaner
                              Funnel
                              Small fasteners, crimp connectors & hose clamps
                              Anti-seize
                              Extra fluids
                              I can put a tool on just any fastener on the car.
                              It depends. If I’m going far away, I’m going to be able to fix most things. I’ll pack more parts the further I travel.
                              Parts I keep on hand
                              Wheel studs and nuts
                              Spark plugs
                              Ignition coils
                              TPS
                              Brake pads
                              VANOS line
                              Parts I need to start packing for long trips
                              Belt
                              Tensioner & pulley
                              Water pump
                              Slave cylinder
                              Master cylinder
                              Gas pedal
                              Throw out bearing (yes…I’d do it at the track)
                              O2 sensors
                              Camshaft sensors
                              Crank sensor
                              Extra front splitter + hardware
