Repeated Error Codes Cause
    I'm sure this was covered on the old M3 forum but, in searching, I can't find anything. I've gotten these codes several times in the past and am wondering if there is something I can do to fix them or if they are indicative of a bigger issue, especially the VANOS errors. Note that I've only really scanned the car when it throws a CEL and is running rough/missing, which has happened a few times over the last year due to old coil packs going out. I've been replacing them with Delphi coil packs as they go and, with the newest misfire, all of them will be new!
    Note that I have not yet overhauled the VANOS system but intend to.
    Codes are as follows:
    223 Saugrohrdruck
    Error frequency : 1
    Logistic counter: 40
    Motordrehzahl 0.00 1/min
    relative Fuellung 0.00 %
    Umgebungsdruck 995.00 mbar
    Drosselklappenwinkel 0.00 %
    aufgetreten vor (rel. BZ) 4.40 h
    0010 - Kurzschluss Masse o. Wert zu klein
    Fehler momentan vorhanden
    statischer Fehler
    ------------------------------------------------------------- 94 interner Index 241
    Error frequency : 1
    Motordrehzahl 840.00 1/min
    relative Fuellung 114.40 %
    Kuehlwassertemp. 83.00 Grad C
    Versorgungsspannung HR 13.30 V
    aufgetreten vor (rel. BZ) 4.30 h
    statischer Fehler
    ------------------------------------------------------------- 184 EVANOS1-Regelung
    Error frequency : 7
    Error occured 1. times at:
    Motordrehzahl 4200.00 1/min
    Oeltemperatur TOG 91.00 Grad C
    Versorgungsspannung HR 13.20 V
    aufgetreten vor (rel. BZ) 3.60 h
    Error occured 2. times at:
    Motordrehzahl 3800.00 1/min
    Oeltemperatur TOG 102.00 Grad C
    Kuehlwassertemp. 85.00 Grad C
    Versorgungsspannung HR 13.50 V
    aufgetreten vor (rel. BZ) 2.90 h
    Error occured 3. times at:
    Motordrehzahl 3200.00 1/min
    Oeltemperatur TOG 83.00 Grad C
    Versorgungsspannung HR 13.60 V
    aufgetreten vor (rel. BZ) 0.10 h
    Istwert zu gross
    Fehler abgasrelevant OBD
    Fehler momentan nicht vorhanden
    sporadischer Fehler
    Probably MAP
