Did you take a plastigage measurement?
Remember, you still have a lot of oil in the engine - cooler lines, cooler, filter housing which could have oil in it with lead contamination.
After major work, I fill with Walmart oil, let it run and then drain from the drain plug, pull the cooler lines from the cooler and drain the cooler. Vac out oil in the filter housing and refill with 10w-60.
Do oil changes more often then trend lead levels. You should see lead go down.
