Hi all. I recently did a conversion to DB9 front brakes and 996 rear brakes. Initially, I only changed the front and did a full bleed (500mL) followed by a INPA ABS bleed cycles (1L). Afterwards, the brakes felt vague i guess would be the way to describe it. I would push down on it and there would never be a point where the brake pedal would get “stiff”. It was just a soft travel down to wherever I was braking to. The brakes worked completely fine though. It stops very well, and i even took it to a track day and it felt fine. Now I changed out the rears and did a full bleed again without INPA ABS and the feeling has not changed. I was hoping it was the mix of aftermarket fronts and OE rears that causes the weird feeling but now it seems like it’s here to stay. Again, the brake pedal feels vague without much resistance at any point, but the car still stops VERY well. Is this normal or did I not bleed my brakes right?
BBK retrofit mushy pedal
I did 2 person when I did my fronts. Then for the rears I gravity bled them for a little bit, then installed speed bleeders on all 4 corners and bled them that way.Originally posted by Maxima SE View Postyou probably still have air in the lines. how did u bleed them? 2 person method or with a bleeder?
get a motive bleeder and 64 oz of brake fluid and bleed all 4 corners twice. let the rears run for 2x as long as the fronts. should be good to go after !Originally posted by slowmobile View Post
I did 2 person when I did my fronts. Then for the rears I gravity bled them for a little bit, then installed speed bleeders on all 4 corners and bled them that way.2005 Phoenix Yellow M3 Coupe 6spd
2007 Imola Red Z4M Coupe
