Is my diff completely done?
  • Mattn1192
    Great job. But if you didn't use Super glue to keep the flange on the diff, then don't take the left turn too fast, as we still don't know what had pulled it out.
    I made a ton of figure 8’s yesterday, no issues. A few pulls, no issues. Really have no idea what caused it to pop out. But so far it’s looking back to normal.
  • sapote
    Originally posted by Mattn1192 View Post
    I have my life back.
  • eacmen
  • Casa de Mesa
    Mah dude!!!!!! Congrats! So happy to see this!!
  • Mattn1192
  • mrgizmo04
    Use the classic double wrench technique. Because of the cooling ribs and the vent hole you cant put a wrench in a vertical position, so has to be horizontal.
    Pic borrowed from internet to illustrate.
  • Mattn1192
    Tomorrow should be the big day, stay tuned…..
  • Casa de Mesa
    Check for spark, fuel and compression. Any codes present?
    Bwwahahahaaa! Legit laugh out loud at that!
  • sapote
    When it comes to removing the top right bolt on the diff cover (without dropping diff from car) what’s the best way to do so? I’ve run into a clearance issue.
    I used an adapter 3/8" x 9/16" (HF may have them). The 9/16 hex end fitted into the 9/16 wrench, and the 3/8 square drive fitted to E14 socket. This low profile wrench clears the torsion bar easily.
  • heinzboehmer
    Sway bar has been moved. It’s just the two bolts up top (in pic) does give much clearance up there. Another option would probably be a crow foot with breaker bar.
    They're not torqued super high (33 ft-lbs), so open ended/box wrench is probably all you need. Just watch you hands when they break loose.
    Offset box wrench might make it even easier.
  • Mattn1192
    Jk, feel better man!
    OP, not sure if the sway bar is in the way for you, but moving it out of the way might give you more room. If you unbolt the bushing brackets, you can swing it downward.
  • Mattn1192
    Yeah try open ended wrench.
    I'm not firing on all cylinders today. Recovering from a minor operation earlier today, I should give in and just go to sleep now... 😴
    Hope you’re doing well bro. Be easy 🤙🏽
  • heinzboehmer
  • Casa de Mesa
  • Mattn1192
    Edited my post above. What kinda tolerance are you looking at? I thought there was room
    Don’t have exact measurement, but can barely squeeze a socket through…… right when I thought I was done (after taking out both diff bolts) I run into this 🥴
    Edit: I think a closed end wrench may be my only option. Also, I did notice when I took out both diff bolts, the diff dropped very little. So I made sure the jack was under.
