Hi all. hoping someone here has some insight as to what i'm chasing here that i can't for the life of me figure out. My trunk only opens by either the key hole or by holding down on the remote. the button by the kick panel and the button on the trunk lid dont' work. i've already confirmed the following
- the license plate lights work. considering there's only 3 wires going to the trunk lid, i assume they are power, ground, and signal. this tells me we're getting power and ground.
- the keyhole is NOT horizontal so NOT in valet mode.
- fuse 52 is still good.
- i opened the wire sleeve on the trunk and pulled on all the wires. they're holding well.
- i took my license plate lights/button piece to my neighbors e46 and plugged to his car and it works, so that checks that off the list.
is there something that i'm missing as part of initial troubleshooting before i dive into the wires. does anyone know if the trunk release by the kick panel triggers something that i'm overlooking? is it tied to the trunk lid button.
what's interesting is when i hold the remote button it opens so i'm able to send signal from the remote to the trunk latch. somehow the signal isn't going from the trunk lid button to the latch.
this all started when i had some body work done on the corner of the car and they removed the trunk to respray it. seems obvious it's something there but not sure where to start.
edit: if anyone can direct me to any site that tells me how to test the wires at the connector, that would be great.
