According to TIS when removing the rear axle from the diff you need to replace the 6 E-12 bolts. These bolts are like $16 each. Clearly these are a critical bolt, however do people really replace them each time they remove the axle from the diff?
Rear Axle CV to Diff Bolts Replace or Reuse?
There is an April 2020 version (look for the thread here) that has some fixes so best to look for that.Originally posted by Mpower04 View Post
You can always just double check newtis if you're really worried. For a one off check it's not much effort. Still rate the PDF for quick look ups though.Originally posted by eacmen View Post
Thanks i’ve been burned by this PDF in the past back in m3forum days.
Yep 100Nm = 74 ft lb
