The dash light trifecta followed by limp mode
    My car has been sitting for about two months waiting for my turner csl box return and the delivery of a new Karbonius box to arrive. I installed the new box ( amazing quality) then did a test drive. About 20 mins into the drive the light trifecta (which has happened once or twice before) but this time the car went into limp mode. I pulled over and restarted and it seemed fine. Got home and threw on the code reader and no codes. My first thought was ABS sensors but it’s strange that there were no codes. Should I just replace all the abs sensors or clean them? Any other things I should check?
    Limp mode is due to issue with tp sensors/ throttle bodies. Look into making sure you installed everything correctly
    Sent from my SM-G996U1 using Tapatalk
      That was it, you nailed it. One of the clamps was a bit too close to the linkage. Thank you so much!!
