Originally posted by Tbonem3
View Post
Best Adjustable Spring Perch
I'm over in San Jose and I have H&R lowering springs that came with a adjustable perch, You can see if the perch works with your dinan springs (if it did then it would forsure raise your car, probably not the result you want) or buy the perch and springs together. Your other option is to switch to Linear springs and get an Articulating spring perch from Rogue Engineering / Ground Control / DifTechOriginally posted by cobra View PostRight now I am running Dinan springs on stock rubber pads. The spring rate is fine for my needs, but the car sits unevenly. I don't want to lower the car more than 13.5" fender edge to center of wheel. (Currently at 14 left and ~13.75 right).
What's the best method for getting some adjustability without reducing travel or risking damage?
I would consider switching to straight wound springs as long as it doesn't cause any other issues.
