So here's the background story:
Spun #4 rod bearing. Engine came apart for cleaning/ rod+piston removal. I replaced #4 rod, had the crank machined, and had the head decked with .004" removed. Block decked with .005" removed. My question is how much tolerance do I have for Piston to Valve clearance? Can I re-assemble with OEM Elring head gasket and not worry about valve contact with the pistons .009" closer? I am considering using a set of Schrick cams which may also cause a tighter clearance. Does anyone have experience building an engine with similar concerns? Thanks.
